1999 Lexus LS400 Driver Seat
Old 07-13-10, 08:12 PM
infamousgt
infamousgt's Avatar
Default 1999 Lexus LS400 Driver Seat
The driver seat of my 1999 LS400 comes back fine. But when it's time to pull the seat back forward. it goes a lil and then stalls. Any ideas???
Old 07-13-10, 08:28 PM
LS400GT500
LS400GT500's Avatar
it could be the motor or you could have something stuck i.e. a coin is everything clear?
Old 07-14-10, 03:16 AM
billydpowe
billydpowe's Avatar
4 bolts and it is out of there..... you might can leave it plugged into the harness, just lean it back and see what is going on, then tell us "how you fixed it"
Old 07-14-10, 08:27 PM
infamousgt
infamousgt's Avatar
Yea, everything's clear. I originally thought it might have been a relay or some type of electrical issue. But i'm tryin to avoid the dealer, because everytime u go there, u have to pay an arm and a leg. And these days i dont have any limbs to spare.
And billy, there are just 4 bolts holding the seat to the track???
Old 07-14-10, 08:57 PM
valex
valex's Avatar
Yes, the seat is attached to the floor with 4 bolts (17mm?) Take the plastic end covers and you will see them. Be careful not to scratch the steering wheel with the bottom of the seat when taking it out.
Old 07-15-10, 08:24 PM
lev00221
lev00221's Avatar
I don't understand. The seat reclines but doesn't return to the normal position? Or the seat slides back and wont slide forward? Does the motor keep running and the seat not move? or does the motor shut off when the seat stops moving?
Old 07-18-10, 05:16 PM
infamousgt
infamousgt's Avatar
The motor engages but it sounds like it stops when the seat stops moving. And it just makes a click sound when u move the slider on the side of the seat to move it forward. And it slides back and moves forward to a certain point.
Old 07-18-10, 05:39 PM
lev00221
lev00221's Avatar
It sounds like something is stuck in the railing underneath. Slide the seat all the way back and then remove the front bolts holding the seat down. Slide the seat forward just enough to give you access to the rear bolts and remove them as well. You will likely need a 14 mm socket wrench (preferably with a ratcheting mechanism) to remove the bolts. Once all the bolts are off tip the seat back but leave the harness connected. Then slide the seat forward and backward while looking at railing and see if there is anything stopping the motion of the seat. You should be able to figure out what is wrong by looking underneath while the seat is moving.
Good luck.
Old 07-23-10, 06:23 PM
infamousgt
infamousgt's Avatar
Than guys, appreciate the help. I'll take the advice and see if iit works.
FutureOwnr
03-04-14 10:24 AM
shantm8980
11-08-12 11:12 PM
paulwall86
04-25-11 01:34 AM
caliness
Maintenance
08-06-04 11:40 PM
Quick Reply: 1999 Lexus LS400 Driver Seat
