1995 LS 400 High Idle
Old 07-07-10, 07:01 PM
tkochevar
tkochevar's Avatar
Default 1995 LS 400 High Idle
When I start my car it idles at about 1300 to 1400 RPM's. Would this be the Throttle position sensor? What else should I be looking for and has anyone had this problem?
Thanks,
Koach
Old 07-07-10, 08:10 PM
7schulz
7schulz's Avatar
Mine did the same thing but up to 2000. The TPS or the Idle Air Control Valve. I did this and it helped. Get the gasket for like $3 and I used an old tooth brush to scrub everything I could reach.
http://www.lexls.com/tutorials/EFI/throttlebody.html
Old 12-01-14, 07:02 PM
3foreign
3foreign's Avatar
thanks for the info. I will be doing this on Saturday
Old 12-01-14, 08:34 PM
lexmoose
lexmoose's Avatar
Thanks,
Koach
1300-1400 is normal when cold, this is to speed up the heating of the catalytic converter so they work properly.
If it surge a lot when put in drive, look at you motor mount, I still didn't have time to do mine but it help apparently.
Cleaning the TB won't solve this, but it's not a bad thing to do.
erichuang
11-19-16 08:02 PM
bmatic01
Performance & Maintenance
12-29-15 03:37 PM
oldben
01-29-15 07:10 AM
bkroske
01-25-14 07:46 PM
gsimba
10-07-06 04:20 PM
Quick Reply: 1995 LS 400 High Idle
