Outside temp reading off by 30 degrees!
Old 06-09-10, 06:21 PM
cgreenberg
cgreenberg's Avatar
Default Outside temp reading off by 30 degrees!
The thermometer reading the outside temperature was reading off by 30 degrees for while today. Seemed to fix itself. Coincided with my A/C light blinking and A/C not being real cold. Which also fixed itself
Any ideas anyone?
Th you!
Chip
Old 06-09-10, 06:37 PM
amcdonal86
amcdonal86's Avatar
Is it fixed already? Intermittent problems are hard to diagnose.
Old 06-09-10, 07:47 PM
cgreenberg
cgreenberg's Avatar
it fixed itself on the way hone, but it has done this before.
Yes, that doesn;t make things easy!
Old 06-10-10, 06:42 PM
MeryLexmas
MeryLexmas's Avatar
Check to ensure the outside temp sensor is securely plug in. I had the same problem and the sensor was loosely connected.
Old 06-11-10, 05:12 AM
cgreenberg
cgreenberg's Avatar
Thanks Mery. Where is it located?
Old 06-11-10, 09:21 PM
skperformance
skperformance's Avatar
always post the year of your car in your title.
It is behind the front bumper or just under the rebar.
Old 06-12-10, 04:58 AM
cgreenberg
cgreenberg's Avatar
Th you. You're right. I have a 98
jlawr
07-31-15 12:47 PM
flyboyplo
06-29-13 12:18 AM
jboy
SC- 1st Gen (1992-2000)
06-12-09 09:20 PM
JohnnyCake
07-02-08 06:36 PM
tbrdb0b
RX - 1st Gen (1999-2003)
08-13-07 07:34 PM
Quick Reply: Outside temp reading off by 30 degrees!
