no fast accelaration
Old 05-21-10, 09:19 AM
marcls400
marcls400's Avatar
Default no fast accelaration
my ls 400 runs fine as long as i dont try and hit the gas pedal to fast accelarat at any speed it jerks and i have to let up off the gas and let it take its own time to pick up speed!!!
Old 05-21-10, 09:24 AM
Thermactor
Thermactor's Avatar
You could have a really bad intake leak or vacuum leak. On most other cars the first thing you'd look at would be the fuel filter or the air filter and look for restriction but in this case I'll guess that you have a cracked air intake hose.
Test it out by spraying starter fluid all over the intake pipes and seeing if the revs increase
Old 05-22-10, 01:24 AM
Bill Dowd
Bill Dowd's Avatar
try the MAS and get some mas cleaner and just give is a spray some time that helps!!!
Old 05-22-10, 10:39 AM
bmoore
bmoore's Avatar
Will it rev freely in neutral? If not, it could be a plugged cat.
Old 05-22-10, 10:43 AM
williamb82
williamb82's Avatar
its prolly the ecu, same issue ive been dealing with for 2 months.
SC400Corb
Performance & Maintenance
07-02-19 04:09 PM
vipXjunky
04-14-10 08:10 AM
neurocity
08-29-06 05:06 PM
Quick Reply: no fast accelaration
