Car wouldnt go..Intake filter pops off..
Old Apr 13, 2010 | 11:24 PM
vipXjunky's Avatar
vipXjunky
Unhappy Car wouldnt go..Intake filter pops off..
Hello CL, I've searched for 30minutes for my issues and haven't found anything with the search tool..or maybe I just suck at searching..but here is my problem..
I recently installed an intake, resetted ECU. Let it idle for about 30 minutes...first the car was heavily shaking..and then once the engine warmed up, it stopped the heavy shaking. I tested drived it, everything seemed to be ok. Then when I turned off the car, let it sit for about 1hour and turned it back on, tried to gas it..it would NOT go at all, it went like 5mph even when i floored it...then when i tried to gas it little by little, my intake filter popped off, i put it back on and the car was running ok again..anyone had this problem, can anyone help me out? Thanks guys/girls!
Old Apr 14, 2010 | 01:18 AM
o6spdracer's Avatar
o6spdracer
What kind of intake did you install? I had that issue when I first installed my SRT. Turned out one of the wires was loose. Resoldered it and it was good to go.
Did you check the clamp that holds your filter in place? Maybe it is broken or loose, causing too much air to go in. I'm just guessing.
Old Apr 14, 2010 | 01:24 AM
PureDrifter's Avatar
PureDrifter
BahHumBug
CL Folding 100,000
check your MAF wiring. sounds like the maf isnt hooked up properly or at all. it doesnt matter how tight the filter is on, the car will run fine w/o a filter (dont drive it like that obviously or else ur engine will be full or random crap) as its POST MAF air leaks that cause stalling.
Old Apr 14, 2010 | 06:53 AM
shvc1991's Avatar
shvc1991
You might also want to check your throttle body as your car has gone into limp mode.
Perhaps the TPS sensor has gone bad. There's really not much to the intake/throttle body so it should be an easy fix, but costly depending on what it is.
Old Apr 14, 2010 | 08:10 AM
McKrevice's Avatar
McKrevice
Sounds like the oil from the filter got on the MAF wires.
feng
Performance
Feb 22, 2011 05:21 PM
TexasGS
Performance
Sep 24, 2006 07:59 AM
kapdori
Performance
Sep 13, 2002 12:42 PM
CSHFLW
Feb 6, 2002 06:40 PM
HDDuece
Jan 7, 2002 05:19 AM
