92 LS400 - hard to start when warm
Old 12-16-10, 10:56 AM
JimsGX
JimsGX's Avatar
I was going to suggest changing out that temp sensor, then taking a look at the cold start valve if the problem persists...
Old 12-16-10, 12:24 PM
gmacrae
gmacrae's Avatar
definitely check out the water temp sensor. The one straight under the throttle body if memory serves.
Cold start valve? which one do you mean Jim?
Have you had your car plugged into a code scanner or even checked for codes by jumping the pins in the plug?
You need to stop replacing parts in the hope they'll sort it and get it diagnosed properly
Old 12-16-10, 06:17 PM
JimsGX
JimsGX's Avatar
The cold start injector. I was thinking it may be staying active even after the engine was warm, which is why I asked if he could smell fuel when it wouldn't start.
Attached Thumbnails 92 LS400 - hard to start when warm-ls400-cold-start-valve.jpg
Old 12-16-10, 07:27 PM
gmacrae
gmacrae's Avatar
ahh right, unplug it even - might throw an error but could help pinpoint the problem
Old 07-19-12, 02:20 PM
viper.boy
viper.boy's Avatar
Cuda6Pak,
Did you ever solve the hot start problem the problem?
Old 07-19-12, 08:57 PM
GS4_Fiend
GS4_Fiend's Avatar
Originally Posted by viper.boy
Cuda6Pak,
check fuel pressure and volume underload before assuming..
Old 07-19-12, 10:43 PM
NTRUDA
NTRUDA's Avatar
It might be your crank position sensor if you are having starting issues like this...it may be worth checking to see if it's going bad....let me know and I also agree that you should put a code reader on it--you might have a pending code that hasn't triggered your check engine light....Let me know what you find out and good luck....
lrstephens
11-05-18 09:42 AM
Mike234588
22
05-18-16 04:20 PM
TrAPsTaR87
18
03-27-15 02:30 AM
Banshee365
08-23-09 10:15 PM
lp_yang
09-26-06 06:46 AM
Quick Reply: 92 LS400 - hard to start when warm
