transmission drain and refill capacity?
Old 01-16-09, 11:02 AM
atoyot
atoyot's Avatar
Default transmission drain and refill capacity?
Does anyone know the amount of tranny fluid i should buy if i wanted to do a simple drain and refill on the transmission of my 00 LS 400?
I know that with a simple drain, you do not get all of the fluid out, only a percentage. I would rather know before hand instead of draining it out, then measuring it and then having to go to the store.
I am not a believer in transmission flushes. I personally believe that drain and refill after every several oil changes is a better method.
any help would be appreciated.
Old 01-16-09, 11:34 AM
cation
cation's Avatar
The search feature on this forum is your friend.
PS: 2 qts for drain and fill.
Old 01-16-09, 12:43 PM
LiCelsior
Retired
LiCelsior's Avatar
actually in the maintenance forum, they were talking about tranny drain and refills. someone posted up the percentage of old tranny oil in the tranny after each flush and after the 10th flush there was i think 5% of the old tranny oil still in there.
Old 01-16-09, 12:46 PM
atoyot
atoyot's Avatar
Thanks!
Old 01-17-09, 08:12 AM
AZ Mike
AZ Mike's Avatar
I put my LS400 up on ramps since it is difficult to know where to put a jack until you get the splash guard off the bottom. When I drain the transmission while it is up on the ramps (front tires up), I get 4 quarts out of it.
Old 01-17-09, 08:36 AM
avalon42
avalon42's Avatar
Most of it is stuck in the torque converter.
Old 01-17-09, 09:17 AM
LiCelsior
Retired
LiCelsior's Avatar
Yep that's why u Gotta do mulitple flushes to really get the new oil in
Old 01-18-09, 08:46 AM
AZ Mike
AZ Mike's Avatar
I often forget to buy new tranny drain crush washers at the dealer. Has anyone ever had trouble re-using tranny drain crush washers?
Old 01-18-09, 01:38 PM
MEANDAFAKA
MEANDAFAKA's Avatar
not me, just use some of those pipe tape for a nice seal. talk about fefill, i just changed my trans filter not too long ago. but i will need to drain and refill mine once i can get my car ship to my place.
Old 01-18-09, 08:23 PM
rstu44
rstu44's Avatar
Default Transmission Flush
The transmission pan drain can be even more than 3 qts. Depends on how long the car has been sitting. A flush is very easy. Just follow the simple in lexls.com instructions. Two important points 1) Buy a long 5-6 foot long CLEAR 3/8 hose so you can see the fluid going into a clear 1 gal container next to the drivers door. You want to see the condition of the fluid is coming out (2qts at a time). 2) Be sure you are using ONLY Toyota Type IV ATF fluid. DO NOT go to a oil change garage. They will not put in the proper fluid.
http://www.lexls.com/tutorials/trans...ransflush.html
1jztts
Performance & Maintenance
03-16-09 03:44 PM
damon
Maintenance
03-26-08 06:28 PM
cmc07e
Performance
07-12-07 11:50 AM
Straight6
Maintenance
08-03-04 12:24 PM
lexian
SC- 1st Gen (1992-2000)
06-28-02 11:56 AM
Quick Reply: transmission drain and refill capacity?
