94ls searched forums, Still clunking--thoughts?
Old 09-02-08, 07:46 PM
aggieguy
aggieguy's Avatar
Default 94ls searched forums, Still clunking--thoughts?
Hi guys,
I searched for this clunking noise in the forums but am not exactly sure what it is. I "feel" it around the pedal box and hear it in the front right to center floorboard area going over rough roads and bumps. Seems like it would be right underneath the front center footwell area.
I just replaced the struts and mounts, I also had the sub-frame torqued to specs.
Any other thoughts (UCA, LCA, bushings, etc) that you think I should try next? I read a few different solutions but wonder if anyone might have the "oh yeah, that is definitely ....."
Your brains may help save me some money I really don' have. Thanks again!
~Steve/Aggieguy (94 LS 139k miles)
Old 09-02-08, 09:04 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
dead trans mount and/or loose front subframe.
Old 09-03-08, 12:43 AM
jasonburt
jasonburt's Avatar
Clunking is a classic sign of a busted motor mount. the rubber separates from the metal. You will not know it till you remove the engine mounts. The mount will be in 2 pieces(you will be amazed at how you were driving for so long and your engine wasn't bolted down to nothing).
Old 09-03-08, 05:24 AM
aggieguy
aggieguy's Avatar
Thanks guys. Forgot to mention that I replaced the motor and trans mounts last month before the struts.
Just had the subframe torqued this weekend.
Any other thoughts?
Appreciate your help.
Old 09-03-08, 10:24 AM
PureDrifter
BahHumBug
toasted strut rod bushings, possibility for dead LBJ and/or control arms.
Old 09-03-08, 10:26 AM
aggieguy
aggieguy's Avatar
Thanks PureDrifter! I will give it a look.
Old 09-03-08, 04:22 PM
UCF11
UCF11's Avatar
http://www.planetsoarer.com/celsior/bushes/bushes.htm
I believe this is your problem.
Dont know if most you guys are aware of the planet soarer website, its a great site deticated to the soarer but has Celsior/LS400 stuff and alot of the soarer stuff applys to us anyway.
I suggest everyone has a look,
http://www.planetsoarer.com/indexfull.html
here is a link to the full version.
Hope that helps.
Old 09-03-08, 04:29 PM
aggieguy
aggieguy's Avatar
Thank you. I will give it a look!
Old 09-10-08, 12:33 PM
aggieguy
aggieguy's Avatar
Just an update. Thanks PD and all for your help. Replaced the sway bar bushings and the clunking is gone. Sweet!
RXGS
11-18-11 05:47 PM
dashan
08-13-11 04:50 PM
96ls400ky
03-13-08 07:57 PM
damon
04-22-04 12:36 PM
CleanSC
Performance & Maintenance
04-07-04 10:00 AM
Quick Reply: 94ls searched forums, Still clunking--thoughts?
