low windshield washer fluid light...
Old 04-26-08, 09:11 PM
gqr1c3boi
gqr1c3boi's Avatar
Default low windshield washer fluid light...
gentlemen,
THe light came on one day and I refilled the reservoir but the light stayed on. I called the dealership and asked them what could be wrong and they said it was probably a faulty sensor. it costs $175 to fix!!!! Can anyone offer some insight about a DIY for this?
thanks
Old 04-26-08, 09:25 PM
LiCelsior
Retired
LiCelsior's Avatar
reset ECU and see what happens, remove neg battery terminal and leave it disconnected for about 15mins. reconnect and see what happens.
Old 04-26-08, 09:28 PM
sonyman
sonyman's Avatar
Fork up the cash to replace the sensor. Resetting the ECM won't do jack.
Old 04-26-08, 10:28 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
you may not have to replace it.
http://www.lexusownersclub.co.uk/for...opic=31393&hl=
Old 04-27-08, 05:09 PM
tcbted
tcbted's Avatar
My light came on and stayed illuminated this winter.
The float had stuck at the bottom of the reservoir.
I simply tapped it using a steel cable ... the light went off and
has stayed off for 3 months and counting.
Old 04-27-08, 07:59 PM
skperformance
skperformance's Avatar
Also check the wiring behind the inner fender well by the turn signal it can rub and ground.
Old 04-27-08, 08:06 PM
gqr1c3boi
gqr1c3boi's Avatar
Thanks for the responses guys. I haven't had a chance to get under the car yet but hopefully sometime in the next few days.
I'll have to try that since it seems like the best route at this point. Someone also mentioned it on the thread PD linked.
is636
12-06-15 11:36 PM
booga
SC- 1st Gen (1992-2000)
12-10-10 02:56 AM
cgreenberg
05-10-10 02:11 PM
bmoon_007
GS - 1st Gen (1993-1997)
03-07-05 02:17 PM
gebo
Maintenance
09-18-02 11:45 PM
Quick Reply: low windshield washer fluid light...
