Injen Intake
Injen Intake
Is it normal to idle at 3k RPM? I thought it use to idle a little higher before I installed the Injen intake system. I might be wrong, but the car still run normal though. I'm also getting hot air from engine bay coming in from the vents. Any idea how to fix that? Thanks in advance.
i have an injen intake on my car unfortunately and it idles at 700rpm. the heat from the vents is cause you need to push in the circulate button on your heater control or turn the temp down on the temp control toggle button.
3k rpm at idle? when i cruise at 85 mph, im probably only at 2.5k. something is definitely wrong. do you actually mean 300 rpm?
I would say don't worry about it.. but at 300rpm I imagine the alternator and other accessories are underpowered. Obviously this is only at stoplights and parked with car running, etc. But it *could* cause a nuisance. I'd look into trying to see if you couldn't get the idle up to at least 500ish.
