Nos Kit
Nos Kit
What you guys think if I install a 75 Shot Wet System on a stock 1UZFE engine and a custom intake. Will it be ok? or is it gonna blow? Any info would be great..
but if NOT, then youre good , ive played with nitrous so many times. Had 75 shot wet on my 4 banger, did real good!....you might wanna go 75 "like you said" wet shot just to be safe with atleast 1 step Non-platinum colder spark plug. if it knocks or start pinging, then you might wanna retard the timing by a bit not too much or you'll lose power, well you'll lose power either way by retarding but it'll be safer. always play safe.
v8 should be good with 75 wet, ive seen 150 shot on a mustang pretty good and everybody knows how that engine handles.
i
BahHumBug
Im assuming you know that he has a high mileage motor? if thats the case, then youre probably right.
i
i
the 98-00LS has rods weak enough that they tended to break with as little as 10lbs of boost. so even a 75shot of N2o is not somthing id risk, at least not with knowing that the rods may throw.
any LS made in 99 that gets teh regular mileage is going to have ~100k mi+ maint. records are key.
They made them lighter for reduced friction, which made them weaker. They're very reliable in a stock motor. I'm not sure if they're any weaker than 95-97 rods, since they are also weaker than 90-94 rods.
It was just a thought... since I got a brand new kit taking up space in my storage..but if it's not recommended then I'm not gonna do it...and as for mileage I have 110k on my 99...but thanks peeps...I appreciate the info and advice.
Btw Bomexs14, if thats the case of the rods then you should disregard the use of nitrous.
