DRL removal
DRL removal
i was wondering if the Day time running lights could be removed on a 99 ls400. if so how. without disconnecting the high beams
remove the passener highbeam light bulb and your DRL's will turn off, but the only set back is that you will only have 1 light when you flash your highbeams. if you want it done correctly, a hardwire needs to be put into the system to override this, you can contact Steve @ Luxury Motorworks (626) 256-4849 over here in So Cal and they can help you out.
BrandonIS
12-22-12 06:44 PM
