please help!!! steering wheel wont turn
Old 02-16-06, 06:26 AM
Matsui
Matsui's Avatar
Default please help!!! steering wheel wont turn
I have a 94 ls with ~250k miles.
Since yesterday, I noticed some funky sound coming from the exhaust system especially from underneath the front passenger side. So I drove it to work this morning with these symptoms hoping to get it checked out today. As i was reverse parking my car, it stopped and all the dash lights came on. Also, there was smoke coming from front of the car. I'm not sure if it was coming from underneath the car or from the front grill. There was also some bad burning smell with the smoke. Then I restarted it and pulled it back to park.
Now when i was ready to pull out my car, it started fine, but the steering wheel does not turn. My dash is dark when the car is cold, but one of the light that appears on the dash is red battery light. I'm not sure what other warning lights may be on. The car can move forward and in reverse, but it does not turn
Any idea why this is happening? I will probably have to call a towing truck and get it to the mechanic to check it out.
If you have any suggestions, please let me know.
Thanks.
Old 02-16-06, 06:34 AM
PureDrifter
BahHumBug
PureDrifter's Avatar
sounds like a cross between mass electrical failure and a bad PS rack/pump
Old 02-16-06, 07:05 AM
Matsui
Matsui's Avatar
I got the pump issue fixed @ ~130k miles. Do you think maybe there is a steering belt that broke?
Old 02-16-06, 08:24 AM
Matsui
Matsui's Avatar
Ok, I opened the hood and saw that the serpentine belt broke. I replace the original one after 230k miles. Something must have gone wrong that caused it to break....I wonder what.
I'll be taking it to the mechanic soon. Let's see what he thinks went wrong.
Old 02-16-06, 02:59 PM
PureDrifter
BahHumBug
the belts arent made to last that many miles. something you should have had replaced over 100k miles ago...
Old 02-17-06, 04:42 AM
Matsui
Matsui's Avatar
Yeah, I replaced the belt recently so it was almost good as new.
The mechanic said that the fan mount/bearing has to be replaced because it jammed up and caused the belt to break. The part itself is $320 from lexus.
Old 02-17-06, 07:42 AM
Lexushead
Lexushead's Avatar
Default belt
The serpentine belt on my car is original according to all the previous owner's record and it still looks good. The car is currently at 255K miles. Should I replace it? What's the worst thing can happen if it breaks?
Old 02-17-06, 07:50 AM
Matsui
Matsui's Avatar
Usuallly you will see cracks on the underneath side of the belt with after such a long period of performance. The belt goes through and turns a lot of pulleys in the engine including the fan and as I found out recently, the powersteering. It would be better to replace it than to run into a situation of breaking it. It took me about 45 minutes to replace it (i'm very new to this stuff, so it took longer than average. some can do it in less than 10 minutes).
Old 02-17-06, 01:21 PM
Caoboy
Caoboy's Avatar
yeah i changed mine when i replaced my alternator. the belt is only a few bucks, you should change it if you see cracking on the teeth or worn edges. better to spend a little to save a lot!
nvakalis
RX - 4th Gen (2016-2022)
04-09-18 07:20 PM
Jlacck
03-03-16 12:31 PM
guesswh0
10-08-15 10:35 AM
AEMxRACER
Performance & Maintenance
09-08-09 01:35 PM
KAOZZsc300
05-07-08 11:01 PM
Quick Reply: please help!!! steering wheel wont turn
