Cooling fans not running
Old 10-07-04, 09:54 PM
mastella
mastella's Avatar
Default Cooling fans not running
90 LS 400 127,600 Miles. Engine Warning lights came on. Cooling fans not running. Engine compartment seem extremely hot, although the temperature was at midpoint on the temperature gauge. Can someone suggest probable cause and the proper steps to check it out.
Thanks
Old 10-08-04, 12:02 AM
nthach
nthach's Avatar
Those fans are the auxillary fans for the AC condenser. The engine has its own fan.
Old 10-08-04, 07:17 AM
LexLS
LexLS's Avatar
Check to make sure the fan clutch is not locked. With the engine off, see if you can turn the engine fan. If you can then you should be good. I don't know if I've ever seen the cooling fans in the front running. If you're still worried you may want to replace the thermostat.
nthach, nice avatar .
Old 10-08-04, 01:57 PM
persian451
persian451's Avatar
those fans only run for me when the weather is 100+ in san diego. I wouldnt worry about hte fans.. you should pull the codes or take it in to a mechanic or dealership
Old 10-08-04, 03:06 PM
mastella
mastella's Avatar
Thanks for your help. Checked the engine fuse (5 PIN) under the hood. Seemed ok. Put it back in.
Started engine, warning light went off. Slight corrosion on the pin I guess. I'll keep My eye on it though.
Thanks Again
Old 10-08-04, 03:28 PM
persian451
persian451's Avatar
umm.. that ecu fuse just clears the code temporarly and it will turn on back again. You could always borrow a OB1 scanner or do a self diagnosis on the engine code to find out exactly what is triggering the code.
static88
08-09-16 05:21 PM
MattLS400
38
02-13-14 09:45 AM
lunatik1
11-24-10 12:46 PM
tinygs
Performance
07-01-02 11:48 PM
Quick Reply: Cooling fans not running
