need a little guidance
just bot a 95 LS 400 with 105k, lights in the stereo system and the heated seats don't work. also need to adjust the headlights on low beam upward. the climate control lighting works and i noticed that when i turned the climate control to max heat the radio lights flashed for an instant, but stayed off. any help would be appreciated, i have access to a friends repair shop and want to try to be economical, so please advise.
Re: need a little guidance
You might want to have a load test done both on your alternator and battery when you get a chance if the lights flashed briefly on the CC unit when you put it on max.
If the lights on the stereo are out you probably need new bulbs inside the unit.
If both heated seats are out it might be a fuse so check them.
If all checks out fine you probably have a short somewhere.
On a level ground check the "levels" right above your lights. They really shouldn't need adjusting unless the housings were changed at one time or the car was hit in the front
