Trip A and Trip B, Reset buttons not working
Old 12-17-23, 12:41 AM
ForzaRoma
ForzaRoma's Avatar
Default Trip A and Trip B, Reset buttons not working
Hi. I own a 1992 Lexus LS400. I noticed today that my Trip A/B button and Trip Reset button are not working. The Trip meter will count miles but the buttons are not working. You hold the button for over 2 seconds and it doesn't reset like it used to. What is also weird is that every time I turn the key it will switch from Trip A to Trip B. For example, my car will be in Trip B. I drive it. I take the key out. I put the key back in the ignition and turn the key, my car now will be in Trip A mode. I take the key out, then I turn the key again and now the car will be back in Trip B mode. Has anyone else had this problem before? If so, do you know what it was? A response would be greatly appreciated. Thank you.
Old 12-17-23, 09:10 AM
CELSI0R
CELSI0R's Avatar
This problem is very likely related to your other thread on your light dimming not working:
https://www.clublexus.com/forums/ls-...-at-night.html
It sounds like your mechanic either broke the connection to or did not reconnect your cluster bezel that has the warning lights, dimmer switch, and trip buttons
When you turn the key on, do you see the warning lights appear momentarily on your cluster?
It may be better to continue this in your other thread. At this moment I would suggest removing the bezel and checking the wiring and connections
Old 12-17-23, 02:59 PM
ForzaRoma
ForzaRoma's Avatar
Hi. I ended up taking my car to a different mechanic and he found out the dimmer was disconnected by the other mechanic. So I no longer have a problem with the center console, odometer and stereo display from lighting up. Just now, I noticed these trip reset buttons aren't working. I took part of the cluster bezel off and looked behind the buttons to see if the buttons need to be touching a piece. But there is no plastic piece behind it. So I don't know what to look for or if there is a piece broken from the mechanic taking out the cluster.
Old 12-17-23, 03:00 PM
ForzaRoma
ForzaRoma's Avatar
Hi. I ended up taking my car to a different mechanic and he found out the dimmer was disconnected by the other mechanic. So I know longer have a problem with the center console, odometer and stereo display from lighting up. Just now, I noticed these trip reset buttons aren't working. I took part of the cluster bezel off and looked behind the buttons to see if the buttons need to be touching a piece. But there is no plastic piece behind it. So I don't know what to look for or if there is a piece broken from the mechanic taking out the cluster.
Yeah. Those lights come on when I turn the key on
Old 12-17-23, 04:24 PM
CELSI0R
CELSI0R's Avatar
Oh that's great news. So it was just the connector
Good to know that your warning lights are working. So we know that connector is getting power.
The only thing left to do now is to test for continuity between the pins for the Twin Trip Switch on the bezel.
Please follow these steps below:
Testing for continuity:
Attached Thumbnails Trip A and Trip B, Reset buttons not working-1990-1992_ls400_twintripswitchdiagnostic.png
Old 12-17-23, 05:34 PM
ForzaRoma
ForzaRoma's Avatar
https://www.youtube.com/watch?v=E9MsyLZF0r4
Thanks Celsior for the information. I appreciate it. I was able to fix it myself. Took the cluster out slightly and just put my fingers behind the buttons. Applying pressure. Re-installed cluster and now the buttons are operating again. Thanks for the feedback. Merry Christmas to you.
CELSI0R (12-17-23)
Old 12-17-23, 05:55 PM
CELSI0R
CELSI0R's Avatar
Awesome. Glad to hear it
No parts required fixes are the best. Merry Christmas
ForzaRoma (12-17-23)
Old 12-17-23, 06:45 PM
ForzaRoma
ForzaRoma's Avatar
Thanks! They sure are. Take care
Igoboe
06-30-13 05:47 AM
bigolow
06-23-11 07:04 PM
gs4bkny
11-29-10 06:30 PM
kdub159
07-20-10 12:21 AM
wiredGS400
06-12-07 01:27 PM
Quick Reply: Trip A and Trip B, Reset buttons not working
