One headlight
Old 06-28-15, 05:45 PM
Ltuned01
Ltuned01's Avatar
Default One headlight
My 01 gs300 only has one headlight. I had aftermarket halo headlights with 10000k hids installed and have been working great.
Now, the Passenger side headlight doesn't work at all. I even tried switching ballasts and bulbs over and still didn't work. Put a tester to the cord that plugs from the stock wiring harness into the ballast and it showed it was dead. Also, my fog lights don't work anymore and the fuse is blown. Every fuse I replace it with blows instantly when I turn them on from the inside. I was told it could be the relay but not sure. Anyone run into this before? ?
Old 07-30-15, 12:35 PM
XenonDepot
Former Sponsor
XenonDepot's Avatar
Swapping parts one at a time from the non-working to working side should help isolate the issue. When you find the part that is not working the problem will follow to the other side and the working part should allow the side that is out to come on. Are you connected to the factory wiring or using a relay harness with these kits? Are they 35W or 55W?
John
Old 08-06-15, 11:37 PM
Ltuned01
Ltuned01's Avatar
It should be connected to the factory wiring. And they're 35W
Old 08-07-15, 07:52 AM
XenonDepot
Former Sponsor
XenonDepot's Avatar
Hi,
It sounds like you may have a problem with your OE harness. Check your fuses.
Steve
Old 08-07-15, 08:03 AM
XenonDepot
Former Sponsor
XenonDepot's Avatar
Careful when purchasing Philips on Amazon...Tons of fakes.
Steve
Irish49
IS - 1st Gen (2001-2005)
01-13-16 06:38 PM
Shiryo
07-06-13 02:16 AM
ICONYQ
Performance & Maintenance
10-22-12 03:06 PM
olmytsi
Florida Lexus Club
01-28-11 01:19 PM
olmytsi
Florida Lexus Club
01-28-11 01:18 PM
Quick Reply: One headlight
