DRL Pics PIAA Intense White?
well i don't have PIAA white... I have a set of white bulbs and its yellowish in drl mode and white in high beam... don't know why is that but I will switch to leds to see what happens
There is a resistor that limits the power to about 50% while in DRL mode and full power at high beam mode.
If you get the LED either get the compensator which is a plug and play with the wire harness and by switching to LED you loose your high beams
or just unplug the resistor and jump the wire.
Lexusblack
RX - 1st Gen (1999-2003)
06-13-14 05:49 PM
