how much effort to retrofit D2R bulbs into the stock GS halogen headlights
How easy/difficult is it to retrofit the stock HID bulbs (D2R) into the standard GS halogen (9006) headlights?
Like Henry said, putting in not hard. You need to find the right focal point, therefore light will reflect on the road correctly. I tried that before, hard to make a good light pattern.
Master Thread Closer!!
The hardest part is probably centering the HID bulb to the 9006 base...and securing it down in that absolute position....then trying to do another one exactly like it.
Also...make sure the return ground wire in facing down (6 o'clock) position in the 9006 base when locked-in place.....so that the cutoff line is facing upward as it should.
