Stock HID? Failure
Old Apr 18, 2009 | 05:11 PM
gs4play's Avatar
gs4play
Default Stock HID? Failure
I turned on my headlights today and one of the bulbs just flickered and shut off, do the hid bulbs just burn out like that? I really do not know too much about HID's, just looking for some advice. Is it an easy fix or should I just take is somewhere?
Old Apr 18, 2009 | 07:32 PM
skurks507's Avatar
skurks507
Yea, you can order replacements via ebay. I did my last summer. You'll want to replace both of them as the color will be off. If you do some searching, you'll find some DIY's for it. The bulbs run about $100 a set, and the install will take you about an hour if you've never done it before.
Old Apr 18, 2009 | 08:30 PM
swat1727's Avatar
swat1727
i would swap the other bulb to the broken hid and test it first to make sure it's not ur ballast that's broken
Old Apr 18, 2009 | 08:35 PM
neurocity's Avatar
neurocity
Not quite my tempo
6000k if your getting replacements. I had 6k's in my SC and loved it.
Old Apr 19, 2009 | 10:53 AM
gs4play's Avatar
gs4play
thanks for the info guys, I will search for the DIY.. I am not sure if I am using the right terminology but I can see the bulb flickering. When it goes out if I turn my headlights off then back on the bulb is working again, but instantly starts flickering again.
Old Apr 19, 2009 | 01:17 PM
Kyle Harty's Avatar
Kyle Harty
Like was said above, try switching the bulbs and see if the problem switches sides before you order anything. The bulbs will be the easiest thing to check, if the flickering switches sides when you switch them it's the bulb, otherwise it could very well be the ballast.
poley1
Sep 4, 2012 04:24 PM
tmf2004
Lighting
Jul 7, 2012 07:42 PM
Numbahz
Apr 10, 2011 05:26 PM
bruceb58
Mar 14, 2010 02:54 PM
Accord 04
Lighting
Apr 30, 2007 12:06 PM
