- question on tese wheels
- Which tires
- Lexion 503's or RoJa Forged F1's???? Anyone?
- Need a little advice regarding tires...
- Ace Forged Wheels
- is +35 offset too aggressive for a 2nd gen GS?
- Blue SC on Blitz wheels?
- Pininfarina By BBS Wheels?
- replacing fronts and not rears?
- Which one is it ?
- 20" wheel upgrade
- Figuring the right offset/tire combo for your car. Calculator links
- Searching for the perfect Shoes...
- who has these tires??? Bridgetsone Potenza RE040 Run Flat
- I bought 18's with an offset of 45 - should I have gotten the 38's?
- Can anyone tell me what these are?...
- Curb rash
- Changing from 16" to 19" wheels & alignment
- Does tire weight matter like wheel weight?
- alignment check?
- Hi guys..new to this side........
- Buying used wheels, need locks, lugs, and rings?
- 18x10.0 All around on SC400. Need tire rec.
- Wheel Spacer Questions
- how thick to go on tiers so it will not rubb?
- Vibration!!!!
- Opinions on wheels.
- 97 factory wheel drop
- Center cap for supra TT wheels?
- Radura Forgiato clear wheels!
- Bridgestone Turanza Serenity
- 18 X 8 30; 18 X 9 33 - GS400, will these fit and anyone have tire recommendations
- I want to polish my TT wheels but........
- Help identifying wheels
- cheap tires
- What are "Z Rated Tires"
- Bulge on sidewall... Input please .
- Spacer Question!?!?
- MKIV Supra N/A wheels on SC300?
- is 19x9.5 +38 too wide for 2gen GS fronts???
- some advice on these wheels plz
- will this fit on a 92 LS?
- tire fitment question
- Rx Oem 18's On An Sc300
- gs 430 wheels
- A qeustion for JDM wheel experts regarding OZ Futuras.
- 2000 mustang rims on LS? will offset fit?
- Lowering Advice...
- Rotora Brakes Touch Up Paint
- HELP, steering wheel shakes
- wheel size and specs for gs350 help
- Photo Request - iForged Trials
- Camber Wear
- TPS Sensor Compatibility between cars
- I need to know name of those rims ...
- **WORK WHEELS 2007 Updates - New Models, New Sizing, Discontinued, ETC**
- Tires Q
- what size tire to buy?
- Changing the barrel/ring
- tpms question?
- SSR Professor Pricing?
- Question about rims-
- What wheels do I have?
- Tire stretch question
- what are the pros/cons of a reversed lip?
- gs430 rim ?'s
- Will 01 Ls 430 18" Wheel Clear Bbk Mkiv Tt
- Tire recommendations for '99 GS400 ????
- Lets talk Drag Radials......
- TRAFFICSTAR owners : advantages and disavantages of anodized lips
- 1st gen GS assistance needed- f18x9 +21 r18x10 +33
- fittment/offset question
- GS400: 19x8.5 +30 and 19x9.5 +25 too crazy?
- Rubbers
- Check System Light...
- Has Anyone Run Into This Problem 255's w/20x10 Rim?
- 1994 LS400 RIM help
- Compatible with tire pressure sensors
- Wheel protectant?
- location help...
- HELP: will 98 gs400 lowering springs fit on 01 gs300
- rubbing issues
- sc400 with is300 wheels
- Wheel offset questions 20" x 10" with 35ET on a SC
- TPMS on ES350
- BBK Fitment?
- Stock Lexus Rims
- need tire stretch opinion (pics)
- SC Owners, Wheels ? need ASAP
- Dunlop Winter Sport M3
- HELP: Price Determination of used wheels
- calling all wheel gurus
- Offset Help!! I need info ASAP! (searched)
- Where do I go for a Rim Repair?
- Wheel Tire Look and Options
- Need 225/60/16's for quiet, soft and smooth ride
- fit 20x10 rear on SC4..
- Buying wheels from Capital factory wheels
- will +25 offset fit the rear?
- will +25 offset fit SC300 in the rear?
- will these offsets work for gs400?
- recommendations needed for wheel repair shop
- Tread
- need advice on wheel/tire fitment
- What Spacers Are Needed For Stock GS Wheels?
- old member..new to modding
- BBS = filing for bankruptcy??
- Tire Size for 20's on 2GS
- Question about wheels and lugs
- Advice please: Purchasing new tires, and how to avoid nasty tire noise?
- Anyone here Painted/PowderCoated their wheels?
- Looking for some help!
- Brembo BBK
- Help name of this wheel
- different tread patterns ok?
- Could You Actually Drive on These?
- Top grade quality alloy for wheel manufacturers?
- What offsets do I need?
- 50mm offset too much for 1st gen GS300?
- Wheel offsets/disk type on Blitz GS
- Dang, Lexani bought Kinesis!!!
- Where to buy Volk wheels?
- 19" Ruff Racing quality and weight ??'s
- and 4 months later....
- Dangers of adapters?
- LS430 Alignment Specs
- What Rims Are These?
- what is quality of iForged wheels ?
- Michelin Tire Size
- Tire shopping for the new 20's...Anyone try the Falken FK-452?
- 42 PSI = Too much?
- tire size help
- Offsets for SC300? Will these work...
- Any problems with 235/35/19's on GS 300 AWD?
- QUIET and SMOOTH tire PREFERENCES?!?!?
- Wheel Width/offset version 68
- Possible brands for 225/35/20?
- will these offsets work for 2GS?
- Thinking about buying some Zauber Gettins
- Widest tire for a 10 inch rim?
- Staggered Help please...
- Can I run 225/50/17 on 17x8 rims?
- wheel fitment question
- Does Anyone Know Who Makes These Wheels????
- Has Anyone Ever Put A Staggered Set Of 20's On A 3g Gs300 Awd?????????
- Check Inflation System 06 GS 300 AWD
- Eau De Rubber: Kumho Rolls Out Scented Tires
- wheels
- SEVAS S22 in Gold Finish
- For those SC owners that are on a rims budget,...
- Wheel offsets for GS350 and GS430
- Thoughts on 18 vs. (19 or 20) please (on 1st Gen LS400)
- best winter tire?
- Will these offsets look bad on the gs
- 255's won't even fit on the OEM 450h rim. bah!
- Has anyone seen these OEM rims?
- VELLANO FORGED Wheels : Availible from D2-AUTOSPORT
- test fitting euroline DH on ucf11
- Looking for opinions on RPM 507 wheel
- What wheels are these?
- Valve stem broke on IS350
- Best tires for my '01 ES300?
- Who makes these wheels?
- stretching the tires....
- Discount from Tire Rack?
- Bridgestone Tires..Ouch....
- rolling front fender with fender roller?
- Tire question about 19" wheels
- Dilemma With 20' Wheels For My GS. HELP!
- TPMS Metal Strap Question
- Will these rims fit my sc4?
- Look what brown brought today...
- Asanti 128's vs. Auto-Couture Latives's? Differences?
- Need Tire Specs For Putting 19's On 2000 GS300
- Rub
- TT`s on SC`s
- Can Anyone Identify These Rims?
- 19x9.5 with high 20s offset rear doable on ISx50??
- widest front tire.
- Got Specs For My Wheels. Advice Needed.
- Optimal tire size for RX350 rims on a 2GS
- ACE AMF 010 forged wheels
- Tire Rack Website New Feature Comming Soon!
- Godfather rims
- wheel offset
- Mich Sport vs. PS2 vs Mich Sport A/S
- Question for 2GS wheel experts...
- 245/45ZR18 XL Dunlop SP Sport Maxx Blackwall
- Anyone using a 255/40/17 tire on a GS400?
- Help me decide...
- Tire size for 20 inch rims?
- Will TPMS Be Ok? (Pics)
- Rough NYC streets... which size next...
- Help installing adapters
- Who Makes These Rims?
- Rim Rash Damages, DIY Fix?
- What series tire on a 19x 8 w/ +42 offset?
- Nice lookin rims
- Correct Inflation?
- wheel lip ring
- What you think about this wheel?
- Speedline Centercap Question
- lost wheel lock key!
- New MRR Wheel Model Availible (HR4)
- ?, will 2000 GS 400 5 star rims fit an '01 IS.
- Why 35 series in front and 30 in back?
- Abnormal inside tire wear 2004 GS430
- Anyone have American Racing 20 Inch RTS Wheels on 2nd Gen GS?
- will OEM G35 wheels fit the ISx50?
- mini-report Bridgestone RE960AS vs Pirelli PZero Nero
- Experience with these tires?
- i can get a really sick deal on 20 offset 19's
- Will JDM Aristo wheels fit 2nd Gen GS?
- how will these sit on a 2nd gen GS?
- Will these sit flush?
- Anyone got these TRD 19"
- Help with bent rim
- Black Chrome Wheel (!?)
- will 245/ 50 fit on 16" Platinum Edition wheels?.
- 15" wheel fitment on a GS430?
- Will this Fit a 2000 GS 400?
- Wireless TPMS on TR's site
- SC400 and these wheels... will it fit?
- IS300 wheels and tires
- Fixing curb rash
- Wheel/Tire Help
- Tire Pressure
- Load Index
- Which wheels are these?
- wheel people i need help w/offset choices 2gen GS
- Kics Spacers and Hub Rings
- Snow Tires
- Need Help with Center Caps
- 20x9 rim in front....245/30/20 or 255/30/20
- Tire size question and centercap question
- Need Prof. Advice - Will These Fit my IS350???
- Need help on deciding which of these chrome "shoes" for my GS 300
- What spacers do I want ?
- i found these rims...BUT WOULD THEY FIT ON MY SC?
- ? about tire size with rims
- HELP NEEDED! Will these tires fit?
- will these fit??
- will these fit my sc400
- Are these wheels nice/good deal? Let me know!!
- Advice on A/S tires for 18" rims
- Best comfort tires for GS350AWD
- Help! Wheel Spacer Fitment Question!
- Need some winter tire/rim help
- So what do you guys think about this wheel?
