2002 Sc 430 keyless entry does not work
Old 08-23-10, 11:33 PM
Silverhope
Silverhope's Avatar
Default 2002 Sc 430 keyless entry does not work
Hi,
I cant use the keyless entry to open the doors. At first I thought it was the battery, so I had it replaced. However, the keyless entry still does not work. Does anyone know how to fix this problem? Thanks in advance.
Old 08-24-10, 06:35 AM
daryltrinh
daryltrinh's Avatar
What a bummer.
Even to this day, Lexus hasn't mandated keyless entry/ignition for the SCs.
Good luck bro.
Old 08-26-10, 08:05 AM
offroad200
offroad200's Avatar
Originally Posted by Silverhope
Hi,
I'm assuming you're talking about using the remote built into the key? Does that light on the key come on when you hit a button? If so, if you press unlock twice does the passenger door open? If it does I would guess it's the driver's door lock assembly. If nothing works, you can get your dealer to check your key. They should have a tool that measures signal strength of the key.
mpdelnorte
12-07-16 08:42 PM
zyumin
09-28-16 12:35 PM
xplosiveg
04-06-12 12:14 AM
Rustito
11-03-11 06:20 PM
drsaab1
02-15-06 07:04 PM
Quick Reply: 2002 Sc 430 keyless entry does not work
