Old 12-15-14, 01:10 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Interior
Print Wikipost
HOW-TO: SC300/SC400 Install Aftermarket Head Unit, OEM Speakers and Sub Working!
Old 03-09-16, 02:16 AM
  #556
KahnBB6
KahnBB6's Avatar
Received 1,221 Likes on 856 Posts
Originally Posted by raine
Yeah... 80's GM OEM stereos were so bad.
Like I said dude - whatever floats your boat. You don't have to explain why you prefer the OEM stereo, all I was saying is that for the sound "quality" (90's quality) it offers it's not worth the trouble. But by all means, if you want to keep the OEM then that's fine, you have your reasons.
Plus, an SC isn't a classic. At least not the one we got here in the U.S. Heh
I understand. I'm aware it's been greatly surpassed by today's standards. For me I'm happy as long as it works as is. Whether I can keep it in there and use other nearby electronics is another story, so it may not stay for much longer despite my preference.
I beg to differ about SC's not approaching classic status though, especially if you add a bunch of hardware from the non-US versions or MKIV Supra to bring the driving experience in line with the looks. I do feel Toyota (and Nissan) in the 90's gutted these things for the U.S. market they were initially designed for. But that trend is still going on today with plenty of new models.
Anyway, thank you for your help with this, Raine! The possible noise on the shared +12V Constant and/or +12V Switched connections in addition to the ground location are the last things I will look into changing. If that doesn't work... then the OEM HU's days are numbered.
Begs the question though: would recent aftermarket HU's also get even some electrical interference noise from sharing the same two types of +12V connections through the factory stereo harness with another electronic device like an LXCC or... anything similar? Obviously the ground connection is always the first thing to check.
Old 03-09-16, 11:34 AM
  #557
raine
raine's Avatar
Classic by model year, sure. But "classic" in the true sense, not the SC. Maybe the Soarer (which had the right engine)... but here in U.S. the SC was just an overpriced Toyota that filled in a small gap created when the Lexus brand launched and it needed a 2-door offering ASAP. If it weren't for the whole "drift era" in the early 2000's there wouldn't have been this resurgence of interest in the SC. If you want a true classic late 90's Japanese 2-door, the SC is nothing compared to the Supra. You don't have to "add a bunch of hardware" to a Supra to make it something it isn't.
Don't get me wrong here - when I had my SC I loved it, but I had to do/add/mod/change a lot of it to get to that point (my build thread shows just how much LOL). For me, true classics are exceptional and unforgettable straight out the door
no prob, sir
Sure, they can - aftermarket or not - because you're still sharing a 12V+. If anything, I would leave the factory stereo power wire (12v+) to power the head unit only, and nothing else. If you have no choice but to splice to get power to another electronic device, at least splice into a harness that has nothing to do with audio components (i.e. cigarette lighter harness). By doing it this way, you at least keep the audio isolated from everything else, as intended. If there's electrical noise generrated elsewhere, at least you won't hear it through the speakers.
That scenario I described with the amp draw is a very common problem, usually happens when people install car audio and try to use one amp cable to power everything by splicing everything along the amp line. Like I said before - the issue is caused by the amp draw of one device being higher than the maximum amp draw that the other device(s) are capable of seeing. BTW don't confuse this with bad ground - having a bad ground can also cause noise but not in the same way. A simple way to kind of describe the difference is:
Shared amp draw = like saying, there's too much trying to go in
Bad ground = like saying there's not enough space to get out
Does that make sense?
Old 03-09-16, 12:59 PM
  #558
KahnBB6
KahnBB6's Avatar
Yes! That's a great analogy.
I am going to go back to the harness I made and separate out the +12V Switched signal to draw from the cigarette accessory splitter harness that's already done in the car.
However I also should do the same with drawing my +12V Battery/Constant signal from somewhere else, correct? Do you know of another good location for that?
Old 03-09-16, 01:12 PM
  #559
raine
raine's Avatar
It depends on what the other 12v+ constant is for. If it's just for memory purposes (i.e. radio settings, accessory memory) then generally it's a very low amp draw. Usually with head units the 12v+ switched is the main power supply. Whatyou would need to find out is how the LXCC thing is configured - I would guess that either it:
A. Uses 12v+ constant into an internal main power relay activated by a 12v+ switched (so high amp draw would be through 12v+ constant)
OR
B. It uses the "stereo" style power setup with the 12v+ constant for low-amp memory retention only, with the main power being through the 12v+ switched (so high amp draw would be through 12v+ switched).
That said, based on what way the LXCC is wired, just be sure to isolate the "main power" wires for each accessory; in most cases the memory wires don't draw enough power to cause noise. Ee: my old setup had the head unit 12v+ switched wire isolated from the EDFC 12v+ switched wire, but the EDFC 12v+ constant (for remembering my presets) was spliced into the OEM head unit 12v+ constant. Bear in mind the EDFC was wired directly to the 4 electrical motors on top of the shocks... but nope - I had no electrical noise.
Old 03-09-16, 08:27 PM
  #560
Sc300i6
Sc300i6's Avatar
Default All time current
Hey man I did exactly what you stated on this thread but for some reason I get the head unit on at all times. Even with the key not being in ignition switch I also notice that if I unplug the antenna that's the only way it goes off. Here is my number 8055589572 if you can call me to better explain..thanks
Old 03-09-16, 10:24 PM
  #561
raine
raine's Avatar
You might have your 12v+ and ACC wires switched.
Old 07-18-16, 01:48 PM
  #562
shauns
shauns's Avatar
Raine. I do alot of custom installs. The fact that you were awesome enough to go out of your way 7 YEARS ago and do this thread up for everyone is amazing. Best thread I have EVER read online and way too good for just a thread, should be in a manual. The fact that you are still helping people too after all this time only shows how I am right about you and for you doing this in the first place. Ignore any "person" who throws negatives your way because they could never be you ... FACT. Thanks for doing this and helping so many with this. My hat is of to you.
Old 07-18-16, 04:29 PM
  #563
raine
raine's Avatar
As long as it's still in my memory, I help when I can
Old 09-07-16, 11:26 PM
  #564
ar3
ar3's Avatar
I'd also like to thank you for writing this up man. I bought my 97 a month ago and took apart the head unit and the previous owner did exactly what you did so I'm confident it wasn't a hack job.
Old 09-08-16, 11:17 AM
  #565
raine
raine's Avatar
Glad to help buddy
Old 10-12-16, 12:55 PM
  #566
mrmax512
mrmax512's Avatar
Default Worked!
I used Metra Harness but not for sub amp integration. I just hooked up the RCA like above. But I made my own RCA to speaker wire by using the shielding as ground and the middle wire as positive. This is on a 95 SC 300 with Pioneer system, 155K. Thanks for this post!
Old 10-12-16, 01:33 PM
  #567
raine
raine's Avatar
no worries, cheers
Old 10-13-16, 02:08 AM
  #568
krbrabeck
krbrabeck's Avatar
Has anyone done a writeup like this for an SC300/400 with the Nakamichi head unit and amp? I quite frankly don't want to go through all 38 pages of this thread to look, and if it hasn't been done, I'd like to do it. Any help would be appreciated. Please don't ask me to use the search feature...If I had tried that and found my answer, I wouldn't be here.
Old 10-13-16, 09:02 AM
  #569
raine
raine's Avatar
LOL quite frankly, if you don't want to go through all 38 pages of this thread to look, how about reading the first few sentences of the very first post:
PLEASE READ THIS INFO ON TWO IMPORTANT SUBJECTS FIRST:
#1 - This is for a PIONEER SYSTEM. Not a NAKAMICHI, no matter how many times you ask!
Everything in this how-to was written for a Pioneer system. All of the wiring locations and specifications were based on a Pioneer system. If you have a Nakamichi system, this DOES NOT work as written. I can't help you with your Nakamichi system, though some people have posted in this thread how they got it to work.
Old 10-14-16, 04:50 PM
  #570
dicer
dicer's Avatar
When it comes to car radios I like the old stuff, just easier to work, I like ***** especially for the volume.
krbrabeck I'm with you on the search deal. I am amazed how it can't even find some posts I have done.
Its just so simple for a person to just say what it is, rather than waste the time and effort to say "search it".
Quick Reply: HOW-TO: SC300/SC400 Install Aftermarket Head Unit, OEM Speakers and Sub Working!
