Subwoofer / Amplifier install question
Old 01-12-15, 08:35 AM
  #31
sessionstu
sessionstu's Avatar
Originally Posted by gennacide
It sounds better if you aim it towards the back of the trunk in my opinion. I have the same car and same sub.
Really? I'll have to try that. To be honest, I haven't driven the car much since installing the sub. What settings do you have on the sub amp, LOC, and stock head unit. I'm still trying to find the optimal settings.
Old 02-13-16, 03:58 PM
  #32
Sight22
Sight22's Avatar
I decided to put in my sub I have laying around. I pulled out the factory non-ML amp today to see whats doing. Is it better to tap the rear speakers or the sub wire? Are the rear speakers feed full range? Is the sub full range? Not sure where there is a crossover.
Old 02-15-16, 06:21 AM
  #33
gennacide
gennacide's Avatar
I used the factory sub
Old 02-15-16, 01:42 PM
  #34
SLMis
SLMis's Avatar
Any suggestions for a sub/set up that provides just a little more rumble? Nothing too crazy, the stock (non ML) is a bit underwhelming. I was thinking a single 10" but have been told that wasn't enough. preferably around $5/550
Old 06-02-16, 01:09 PM
  #35
waterchng
waterchng's Avatar
Hopefully someone who's done an install can answer this question. I have a 4.75" x 10" x 1.33" subwoofer amplifier to install (it's the Power Acoustik RZ1-1500D). Where would you install such an amp so that it's out of the way? I will have a custom fiberglass sub enclosure in the rear passenger side of the trunk where the first aid kit sits.
Old 06-02-16, 05:10 PM
  #36
specONE
specONE's Avatar
Here's my idea of where I may mount my amplifier, follow links for pictures.
https://www.clublexus.com/forums/bui...ml#post9410093
Old 06-04-16, 08:11 AM
  #37
waterchng
waterchng's Avatar
Thank you, exactly that I'm looking for. My amp is just a tad smaller in all dimensions than yours so I'll place it there too (or rather have my installer do it).
Old 06-04-16, 08:03 PM
  #38
Redshift
Redshift's Avatar
Originally Posted by sessionstu
How are you connecting the remote on the amp? DId you connect it to the stock head unit?
For the remote i used the other smaller harness. Tap into that small white (maybe blue, but the smallest wire) wire.
Old 01-01-17, 04:35 PM
  #39
asiandavid
asiandavid's Avatar
Sorry for reviving a dead thread but I have read everywhere and I still don't know which remote to run some say run the cig lighter fuse some say ecu acc fuse and some say the center console the actual cigarette lighter itself. So my question is what's the best way and the easiest way to get the remote to work mines is a 15 is350 fsport with ml system if that helps
Aleriance
01-02-17 06:39 AM
GS350F
07-17-14 08:38 AM
GreggyG
GX - 1st Gen (2003-2009)
01-02-12 08:01 PM
WIZARD1325
11-11-11 06:43 PM
danger4o5
02-25-08 01:06 AM
Quick Reply: Subwoofer / Amplifier install question
