F-Sport Intake problems.
Old 07-30-14, 04:12 AM
gvan1998
gvan1998's Avatar
Default F-Sport Intake problems.
I just installed my 2014- Fsport intake. Anybody else having engine light issue? I made sure everything was torqued right.
As soon i turn on the engine, the engine light comes on and then the engine shuts off after 5 seconds. I tried to reset the engine code by disconnecting the battery, it does the same thing after i reconnect the battery. Any solutions?
By the way when the engine did not shutoff, I noticed at full throttle, stock intake box sounds better. To describe it, stock intake sounds more deeper with vibrating air noise ( i guess because of the sound gerator). With Fsport, sound level is about the same with stock but it sounds like whining high pitch noise.
Old 07-30-14, 05:24 AM
4TehNguyen
4TehNguyen's Avatar
is the MAF sensor and the one vacuum line installed correctly? Make sure it isnt dirty
Old 07-30-14, 05:35 AM
bigblack06
bigblack06's Avatar
Funny, I have this same issue, car is at dealer right now. I think the ECU needs to be reset for me but this is the same situation just a little bit of a different cause. Try putting it back to stock and see if the light goes away.
Old 07-30-14, 08:43 AM
hovik92
hovik92's Avatar
Make sure there is no leak near the throttle body. The car automatically shuts off after 4 seconds if the engine receives any air that the MAF did not pick up.
Good Luck
Old 07-30-14, 11:04 AM
carderoni
carderoni's Avatar
Interesting. I've installed a Joe-Z intake tube on two 3IS - reset the ECU both times - and with both cars the engine shut off after a few seconds after the first start. Every start after that things were fine, no CEL's or anything.
Old 07-30-14, 11:32 AM
Dark9t316
Dark9t316's Avatar
Mine also shut off the 1st time, but works just fine afterwards.
Old 07-30-14, 12:47 PM
salvadorik
salvadorik's Avatar
Yup same here
EffSport
Performance
08-13-16 03:02 AM
gocubs08
Performance
14
11-13-13 12:11 PM
On3racing
04-02-12 03:00 PM
is350wh
Performance
41
07-10-09 03:57 PM
iKenn
Performance
06-29-08 10:41 PM
Quick Reply: F-Sport Intake problems.
