Wheel Alignment at Dealership
Old 06-16-14, 09:54 AM
saewoo
saewoo's Avatar
Default Wheel Alignment at Dealership
I don't know if this is the right thread to ask this question, but I was wondering if Lexus would do the wheel alignment for free or under warranty. I swapped the springs to RSR Super downs so the springs aren't stock. Since the swap, the alignment if off the center and I'm in of an alignment. It's been 2 months since the purchase. Would it be under warranty or would I have to pay for the alignment?
Old 06-16-14, 10:08 AM
4TehNguyen
4TehNguyen's Avatar
youll have to pay since an aftermarket part is the cause of an issue - bad alignment. Youll always have to get an alignment after messing with the suspension. Usually give it few days to settle. Dealer price for alignment wasnt that much either like $100 or 130
Old 06-16-14, 10:19 AM
saewoo
saewoo's Avatar
Guess i will have to pay for the alignment. Is it better to do it at the dealership or recommended shop from the forum? Do shops and dealers give out the alignment sheet?
Old 06-16-14, 10:24 AM
4TehNguyen
4TehNguyen's Avatar
dealer wasnt that much more expensive than an independant shop so I just did it at the dealer. Hopefully your tires arent unevenlly worn too bad since its been 2 months.
Old 06-16-14, 10:33 AM
dojoman
dojoman's Avatar
Lexus is not going to pay for your alignment since you swap the springs.
Old 06-16-14, 10:34 AM
saewoo
saewoo's Avatar
Well, I've only owned the car for 2 months and the swap of the springs was done 2 days ago, if that matters??
Old 06-16-14, 10:54 AM
dojoman
dojoman's Avatar
No it won't since your springs are no long Lexus springs and off alignment was direct result from swapping springs.
Old 06-16-14, 03:51 PM
onepointon
onepointon's Avatar
It absolutely does not matter. You added an aftermarket accessory that has changed something with the car. Why should Lexus pay for that?
For the record though, Lexus does cover wheel alignments for a period of time. I can't remember the terms off the time of my head, but I believe its 1 year / 10k miles.
Old 06-16-14, 03:59 PM
saewoo
saewoo's Avatar
Thank you so much for the info. Probably i will go to a shop to get it aligned.
RON7
RX - 4th Gen (2016-2022)
01-13-16 02:04 PM
Lveyolfe
01-20-15 10:49 PM
YWW
07-31-14 11:53 AM
User 41924
07-13-14 11:38 AM
Straight6
Suspension and Brakes
03-21-04 10:52 AM
Quick Reply: Wheel Alignment at Dealership
