Help is250 (2014) emblem
I want to remove my rear TRUNK Lexus emblem but I'm not sure how to.... I want to make it gloss black.
Please help... Thanks
Heat it up with a heat gun or blow dryer on low for a couple minutes (this softens the glue), then use fishing line to peel it off.
If you end up deciding you like the car better without, goo-gone and some rubbing alcohol will safely remove any leftover residue.
Exactly as described, use this method.
If you want to spend a little more but with a better quality you can order the BLACK PEARL L badge from Sewell:
http://is.sewellparts.com/accessorie...2013/2033.html
I have the complete kit installed on mine and the quality, in my own humble opinion, looks better than getting it plasti-dipped.
I also used 3M Adhesive Remover after taking the stock ones off, left no residue on and surface was very clean after.
