Tpms Module/ecu?
Tpms Module/ecu?
2006 is250 sport, ml unit, usa spec.
took my car in for the faulty tpms. all my sensors are working but I was told the module must be fried. and Ive been looking for the damn module and can't find it.
I am assuming for my cars spec it should look something like the picture. but where the hell is it. I looked under the glove box couldn't see it unless its attached deep somewhere inside there. looked in the hood... but nope. where is it!!!!
help me out guys.
help me out guys.
It is attached on top of the NAV unit behind the dash. So basically you remove the NAV unit as a whole, and then you'll see the above pictured box on the very top of the NAV unit. Attached with two 10mm bolts I think.
Good luck! Removing the vents above the NAV unit is the hardest part.
thanks should be at the top sounds good
would you know the difference between these parts and how would I know which is compatible with my car?
black one 89760-53010
blue one 89760-53020
Honda2Lexus
10-24-02 06:24 PM
