P0172 code to rich please help!
Old 05-13-15, 06:13 PM
Rvcabrian
Rvcabrian's Avatar
Default P0172 code to rich please help!
So today I scanned my is 250 wondering what the problem was with it being sluggish and stalling in the Rpm and apparently the system is to rich. What can I do to fix this? Clean the maf sensor. anyone come across this problem?
Old 05-13-15, 10:31 PM
Han1s
Han1s's Avatar
I having the same problem with the same code on my is350. Hope someone can help
Old 05-13-15, 10:46 PM
Rvcabrian
Rvcabrian's Avatar
I think I fixed the problem, driving back home it felt usual as it was before the lights were off, unless my dad used the scanner to take it off. Need to ask him tomorrow but it went back to normal as of driving. I'll give some feedback tomorrow. Do you have an aftermarket intake?
Old 05-13-15, 11:27 PM
srt1
srt1's Avatar
P0172
- Faulty front heated oxygen sensor
- Ignition misfiring
- Faulty fuel injectors
- Exhaust gas leaks
- Incorrect fuel pressure*
- Faulty Mass Air Flow (MAF) sensor
Old 05-14-15, 01:47 PM
Han1s
Han1s's Avatar
yes i have an AEM intake so im almost sure that it has something to do with MAF sensor. But how can you fix this ? I dont want to get a new sensor and still have this problem
Old 05-14-15, 10:17 PM
srt1
srt1's Avatar
Get some sensor spray and clean (spray) that sensor. If that doesn't work you gotta find the problem. That's a cheap sensor, maf, compared to the o2sensors, which are far more expensive.
Old 05-14-15, 10:23 PM
BlackFish8
BlackFish8's Avatar
I had the same code and cleaned my MAF sensor and it cleared it up. I would try that first.
Old 05-15-15, 08:43 PM
Rvcabrian
Rvcabrian's Avatar
For most people they would take out the maf sensor and get the spray cleaning for the sensor at autozone and then clean it leave it to dry for about 20 mins and it should do the trick. If not I think it has to be another problem. I replaced my intake to stock and it did the trick. Going to clean and I'll keep you updated
Old 05-15-15, 08:44 PM
Rvcabrian
Rvcabrian's Avatar
Thanks for the help I'll try it out. Going to back my takeda back soon and see if it'll do the trick thanks again!
Old 05-15-15, 08:45 PM
Rvcabrian
Rvcabrian's Avatar
Will do thanks again!
bachlauter
01-14-11 03:15 PM
anoroc1275
Performance
07-28-10 06:22 PM
jimbo22s
Maintenance
12-24-08 02:58 PM
99es300
01-12-08 02:26 PM
Philly RX
RX - 1st Gen (1999-2003)
12-20-07 03:07 PM
Quick Reply: P0172 code to rich please help!
