oil filter recommendations
Old 01-20-15, 10:03 AM
Ants350
Ants350's Avatar
Originally Posted by 604GSE21
didn't lexus also recommended to use 5W20 instead of 5W30 which it was originally said on the owner's manual and the oil cap..
yea what's the deal with that I use 5/30.
Old 01-20-15, 02:34 PM
tomiv9
tomiv9's Avatar
Lexus released a TSB in 2006, changing oil recommendation to 5w20 for 2006 models, but later models (2007-2010) all list 5w30 in the manual/on the oil cap. it appears they changed it, then changed it back.
https://www.clublexus.com/forums/att...mmendation.pdf
Old 01-20-15, 03:00 PM
UniSlayEX
UniSlayEX's Avatar
Originally Posted by Jeff Lange
Within the 2nd generation IS year range (2006-2013 model years, 2005-2013 calendar year production), the same oil filter was used the entire time. The recommended oil was 5W30 non-synthetic for the 2006-2010 IS250 and 2006-2013 IS350, the recommended oil was 0W20 synthetic for the 2011-2013 IS250.
Models that used the 5W30 conventional oil had a recommended change interval of 5,000 mi (8,000 km). Models that used the 0W20 synthetic oil had a recommended change interval of 10,00 mi (16,000 km). The oil filter for both change intervals did not vary, nor was it updated and/or changed in any way once the newer oil/change interval was introduced.
Jeff
Thanks for clearing that up for everyone Jeff, you're a valued source for the community!
My question to you is, Could you take a 2006-2010 IS250 / -2013 IS350 and change to a 0W20 synthetic with a change interval of 10,000 mi? I know others are doing it, but now that we're talking about it I think this would be a great post for newer members and some (myself included) who are hesitant to do so. I know it's not "factory recommended," but given your position I'd like to hear what you think.
Old 01-20-15, 06:32 PM
Jeff Lange
Keeping it Real
Forum Moderator
Jeff Lange's Avatar
A lot of people read that and gloss over a few details, that bulletin is talking about Lexus' introduction of GF-4 oil (which can be used in all Lexus models) and 5W20 grades (which is, as of the printing of that bulletin, now considered a "Lexus genuine oil").
The first note is an important one:
The recommended viscosity grade for this oil differs according to vehicle model.
Use the recommended grade specified on the oil filler cap or in the Repair Manual
or Owner’s Manual for each vehicle.
(This would have always been 5W30 until the 2011 IS250).
The second chart title is also an important one:
Engines That Can Use 5W–20
The recommended oil for the IS250 and IS350 was never specifically 5W20, nor was 5W20 ever actually used in them from the factory. 5W20 was simply introduced and Lexus stated which existing engines could use it. 5W30 was always the grade used for the IS350 and 2006-2010 IS250 and 0W20 was always the grade used for 2011+ IS250's.
It would be hard to say for certain, because there are a few part number changes here and there, though the main rotating assembly is the same between the years. I would think you will likely be fine, but to give that advice as a certainty would be questionable. Toyota has released lists (in Canada at least) for older engines that can use the 0W20 oil, and the 2GR-FSE and 4GR-FSE have not appeared on them.
Jeff
Old 01-20-15, 07:24 PM
akuma88
akuma88's Avatar
my is250 has 122k on it, what oil grade would yall use.
just picked up the car last month, did my first oil change on it, with Mobil one fully synthetic 10w30 but i might change out the oil filter to an OEM one after this thread.
also i live in Houston Tx, and summer is coming up so 95+ degree weather is coming lol
Old 01-20-15, 09:09 PM
kev350
kev350's Avatar
I just changed from 5w-30 con oil to 0w-20 toyota syn oil 6000 mi ago. (2011 IS350)
I'm keeping my fingers crossed
Old 01-21-15, 11:38 AM
UniSlayEX
UniSlayEX's Avatar
Jeff
Thanks! You've addressed my follow up question regarding changes in the engine and if Toyota had addressed comparable oil substitutes.
You'll be fine. There's members that have been running synthetic 0w20 with 10,000 mi change intervals well before this conversation.
heidihidin
ES - 5th Gen (2007-2012)
22
03-03-19 03:27 AM
akim1220
09-22-13 08:51 AM
steveq81
02-23-10 09:36 AM
skiptomylo
10-10-07 03:27 AM
fsdoll
23
05-22-06 10:19 AM
Quick Reply: oil filter recommendations
