aux jack wire
aux jack wire
Hi guys. I have an issue aux port on my is250 2006. Firstly I thought it was the jack itself but now it looks like it is likely to be the wire which the jack is connected to. These are the photos of it. It does not have any markings on it. I was wondering whether I can get it somewhere online. Could you please help me to identify me this part and/or maybe suggest a website where I can get it. Thanks for a response.
You can go to http://is.sewellparts.com/ to browse all the parts and part number. That looks like a very simple wire, maybe you can test it with a multimeter to see if there is anything wrong with it.
Should be easy to fix, like nosurprise said, grab a multimeter (even a cheap $15 one will do) and test the continuity between the pins on both sides. Some meters will have a setting that beeps when you have continuity (a connection between two points), where others will only have a resistance measurement.
