'07 IS250 Won't Start - Dealer Can't Solve
Old 01-13-15, 06:36 PM
djlw
djlw's Avatar
Default '07 IS250 Won't Start - Dealer Can't Solve
Hi friends - sorry for the long post but want to include as much detail as possible.
I owned an '01 IS300 for 14 great years - no issues at 238k miles - sadly it was totaled recently and replaced with the IS250 2007 RWD. I had this car for 24 hours before the first incident of it not starting. Threw a charger on the battery overnight, it started up fine the next day. I chalked it up to bad luck until 2 days later when it wouldn't start again. Startup routine works (instruments fire up, lights come on, headlamps full power etc). This time I took the battery to O'reillys and it tested as 10)% charged, 80% healthy. (Previous owner replaced battery 2/2014). That night I put it on the charger again and next morning fired right up. To be safe I drove it into the Lexus dealership where they convinced me it was a fried alternator - they replaced it at $700. Picked the car up, took it home, that night it wouldn't start again! Had the dealer pick the car up on a flatbed and they are now on day 5 and can't get it started. According to service:
- Charging system (Batt, Alt, Starter, Relays & Fuses) all check out fine
- Battery is fine (I disagree)
- ECU is not reporting any codes or errors from any of the other on-board computers
Has anyone else encountered/solved this? These guys have had the vehicle for 5 days and not made any progress.
I've pasted the car's entire service history below in case there are any clues there that didn't stand out to me. Does seem like the car has gone through some batteries however my 2001 IS300 had to have a new battery every 2 years like clockwork. I also own a 2013 GS350 and a 2013 IS250 which are flawless.
Thanks in advance.
Condition 1 Pay Type: CUSTOMER PAY
Op Code Desc: RR REPLACE KEY AND RE-SEEDED COMPUTER SSC No. ----
RR REPLACE KEY AND RE-SEEDED COMPUTER ~|~CUST STATES WONT START, BOUGHT USED, CAME WITH ONE KEY/ HAD NEW BOUHT ON EBAY, HAD LOCKSMITH PROGRAMMED AND NOW CAR WONT START..ADVISE, ~|~ ~|~95800 150 REPLACED KEY AND RE-SEED COMPUTER Agreement ----
R.O. Open R.O. Close R.O. Mileage Servicing Dealer Service Advisor R.O. No. R.O. Total
---- 02/26/2014 96,158 LEXUS OF WOODLAND HILLS-(60458) 0141143 $0.00
Condition 1 Pay Type: INTERNAL (DEALER) PAY
Op Code Desc: OTHER DIAGNOIS OR REPAIR SSC No. ----
OTHER DIAGNOIS OR REPAIR ~|~OTHER DIAGNOIS OR REPAIR ~|~ Agreement ----
Condition 2 Pay Type: INTERNAL (DEALER) PAY
Op Code Desc: SSC No. ----
PERFORMED TIRE PRESSURE INSPECTION AND ADJUST TO PROPER INFLATION AS MANDATED BY STATE LAW RT FRT_ PERFORMED TIRE PRESSURE INSPECTION AND ADJUST TO PROPER INFLATION AS MANDATED BY STATE LAW RT FRT_ ~|~PERFORMED TIRE PRESSURE INSPECTION AND ADJUST TO PROPER INFLATION AS MANDATED BY STATE LAW RT FRT____ PSI LT FRT___ RT REAR PSI____ LT REAR PSI______ ~|~ Agreement ----
Condition 3 Pay Type: INTERNAL (DEALER) PAY
LOAN CAR DUE BACK DAY REPAIR IS FINISHED. $100.00 A DAY THERE AFTER. GAS CHARGED $8.00 GAL. CAR MA LOAN CAR DUE BACK DAY REPAIR IS FINISHED. $100.00 A DAY THERE AFTER. GAS CHARGED $8.00 GAL. CAR MA ~|~LOAN CAR DUE BACK DAY REPAIR IS FINISHED. $100.00 A DAY THERE AFTER. GAS CHARGED $8.00 GAL. CAR MAY BE REPOSSESSED W/O NOTICE. AFTER HOURS DROP OFF SUBJECT TO A.M. INSP. FOR DAMAGE. ~|~ Agreement ----
Claim R.O. Date Claim Paid R.O. Mileage Servicing Dealer R.O. No. R.O. Total
12/03/2013 12/13/2013 93,091 LEXUS OF WOODLAND HILLS-(60458) 0136698
12/03/2013 12/04/2013 93,091 LEXUS OF WOODLAND HILLS-(60458) 0136698
---- 12/03/2013 93,091 LEXUS OF WOODLAND HILLS-(60458) 0136698 $0.00
Condition 1 Pay Type: WARRANTY PAY
Op Code Desc: BATTERY COMB: BATTERY SSC No. ----
BATTERY COMB: BATTERY ~|~VEH DIED AND HAD TO BE JUMPED CHECK AND ADVISE BATTERY JUST REPLACED ~|~DEAD BATTERY ~|~93091 REPLACE DEAD BATTERY DONE 190011-A T1 -71 T2-72==0.6 HRS Agreement ----
Condition 2 Pay Type: WARRANTY PAY
Op Code Desc: SSC DLA, FRONT WIPER ARM INSPECTION AND NUT REPLACEMENT 2006-2012 IS SSC No. ----
SSC DLA, FRONT WIPER ARM INSPECTION AND NUT REPLACEMENT 2006-2012 IS ~|~SSC DLA, FRONT WIPER ARM INSPECTION AND NUT REPLACEMENT 2006-2012 IS ~|~PERFORM SSC DLA ~|~93091 DLA DONE 3524AA=0.6 HRS Agreement ----
Condition 3 Pay Type: WARRANTY PAY
SSC DLB, INTERNAL TRUNK RELEASE LEVER REPLACEMENT, 2006-2013 IS, 2007-2013 ES, 2013 GS. SSC DLB, INTERNAL TRUNK RELEASE LEVER REPLACEMENT, 2006-2013 IS, 2007-2013 ES, 2013 GS. ~|~SSC DLB, INTERNAL TRUNK RELEASE LEVER REPLACEMENT, 2006-2013 IS, 2007-2013 ES, 2013 GS. ~|~PERFORM SSC DLB ~|~93091 DLB DONE 3611AA=0.3 HRS Agreement ----
Condition 4 Pay Type: INTERNAL (DEALER) PAY
Op Code Desc: CASE # 133340087 APPROVED SSC No. ----
CASE # 133340087 APPROVED ~|~VEH HAS ROUGH IDLE AND SHUTTING OFF AT STOP SIGNS AND LIGHTS MISFIRE CHECK AND ADVISE ~|~ ~|~93091 APPROVED FOR ENGINE JOB SOP PART DONE Agreement ----
Condition 5 Pay Type: INTERNAL (DEALER) PAY
PERFORMED TIRE PRESSURE INSPECTION AND ADJUST TO PROPER INFLATION AS MANDATED BY STATE LAW RT FRT_ PERFORMED TIRE PRESSURE INSPECTION AND ADJUST TO PROPER INFLATION AS MANDATED BY STATE LAW RT FRT_ ~|~PERFORMED TIRE PRESSURE INSPECTION AND ADJUST TO PROPER INFLATION AS MANDATED BY STATE LAW RT FRT____ PSI LT FRT___ RT REAR PSI____ LT REAR PSI______ ~|~ ~|~93091 ADJUST TIRES TO 35 PSI Agreement ----
Condition 6 Pay Type: INTERNAL (DEALER) PAY
LRA Service Date Servicing Dealer Dispatch. No. R.O. Total
11/30/2013 LEXUS ROADSIDE - AAA-(95200) 1899319 $0.00
Condition 1 Pay Type: LEXUS ROADSIDE
Op Code Desc: LEXUS ROADSIDE SSC No. ----
NO START,TTD~|~JUMP START~|~TOWED TO LEXUS OF WOODLAND HILLS WOODLAND HILLS CA Agreement ----
---- 11/15/2013 92,539 LEXUS OF WOODLAND HILLS-(60458) 0135874 $0.00
Op Code Desc: SPECIAL PRICE ADJUSTMENT SSC No. ----
REPLACED FRONT PASS HEAD LIGHT LOW BEAM BULB. ~|~CUSTOMER STATES FRONT PASS SIDE HEAD LIGHT GOES OUT WHEN SET AUTO, IT WILL STAY ON LONGER WHEN TURN ON MANUALLY CK AND ADVISE ~|~ ~|~92539 REC PASS LOW BEAM BULB REPLACE PASS LOW BEAM HEAD LIGHT BULB DONE Agreement ----
Op Code Desc: PERFORMED TIRE PRESSURE INSPECTION AND ADJUST TO PROPER INFLATION AS MANDATED BY SSC No. ----
PERFORMED TIRE PRESSURE INSPECTION AND ADJUST TO PROPER INFLATION AS MANDATED BY ~|~PERFORMED TIRE PRESSURE INSPECTION AND ADJUST TO PROPER INFLATION AS MANDATED BY STATE LAW RT FRT____ PSI LT FRT___ RT REAR PSI____ LT REAR PSI______ ~|~ ~|~92539 ADJUST ALL TIRES TO 35 PSI Agreement ----
Op Code Desc: PERFORM MULTI POINT VEHICLE INSPECTION SSC No. ----
PERFORM MULTI POINT VEHICLE INSPECTION ~|~PERFORM MULTI POINT VEHICLE INSPECTION Agreement ----
11/06/2013 11/06/2013 92,163 LEXUS OF WOODLAND HILLS-(60458) 0135356 $0.00
Op Code Desc: BATTERY SSC No. ----
BATTERY ~|~CUST STATES ENGINE BATTERY HAS TO BE JUMPED STARTED, BATTERY WERE REPLACED ON 07.22.11 RO 155246 MILE 59968 ~|~ENG BATTERY DOES NOT HOLD CHARGE ~|~92163 ENG BATTERY DOES NOT HOLD CHARGE 30 REMOVE AND REPLACE ENG BATTERY. WERE REPLACED ON 07.22.11 RO 155246 MILE 59968 Agreement ----
Condition 2 Pay Type: CUSTOMER PAY
SPECIAL PRICE ADJUSTMENT ~|~SPECIAL PRICE ADJUSTMENT 15% Agreement ----
Op Code Desc: CUSTOMER REPORTS THAT THEY SERVICE THEIR LEXUS SOMEWHERE ELSE. SSC No. ----
CUSTOMER REPORTS THAT THEY SERVICE THEIR LEXUS SOMEWHERE ELSE. ~|~CUSTOMER REPORTS THAT THEY SERVICE THEIR LEXUS SOMEWHERE ELSE. Agreement ----
11/06/2013 LEXUS ROADSIDE - AAA-(95200) 1894485 $0.00
NO START,JUMPSTART\POSSIBLE TOW~|~JUMP START~|~TOWED TO LEXUS OF WOODLAND HILLS WOODLAND HILLS CA Agreement ----
11/28/2012 11/28/2012 79,611 LEXUS OF WOODLAND HILLS-(60458) 0117208 $0.00
Op Code Desc: ENGINE SSC No. ----
ENGINE ~|~CUST STATES VEHICLE WONT START TOWED IN ~|~ ~|~79609 INSPECTED FOUND ENGINE FLOODED WITH FUEL REMOVED SPARK PLUGS AND CLEAN OUT, VEHICLE STARTS NORMAL AT THIS THIS.. Agreement ----
Op Code Desc: PERFORM OIL AND FILTER CHANGE SSC No. ----
PERFORM OIL AND FILTER CHANGE ~|~PERFORM OIL AND FILTER CHANGE $39.95 COUPON ~|~ ~|~79609 LOF DONE ALL TIRES 6/32 FRONT BAKES 2 MM REAR BRAKES 5MM Agreement ----
Condition 3 Pay Type: CUSTOMER PAY
PERFORMED TIRE PRESSURE INSPECTION AND ADJUST TO PROPER INFLATION AS MANDATED BY ~|~PERFORMED TIRE PRESSURE INSPECTION AND ADJUST TO PROPER INFLATION AS MANDATED BY STATE LAW RT FRT____ PSI LT FRT___ RT REAR PSI____ LT REAR PSI______ ~|~ ~|~79609 ADJUST FRONT TIRES TO 35PSI REAR TIRES TO 38 PSI Agreement ----
Condition 4 Pay Type: CUSTOMER PAY
SPECIAL PRICE ADJUSTMENT ~|~SPECIAL PRICE ADJUSTMENT HAS $39.95 OIL CHANGE COUPON Agreement ----
Condition 5 Pay Type: CUSTOMER PAY
Op Code Desc: FRT BRKS SSC No. ----
FRT BRKS ~|~REPLACE FRONT BRAKES AND ROTORS PER CUST ~|~ ~|~79609 REPLACED FRONT BRAKE PADS AND ROTORS DONE Agreement ----
Condition 6 Pay Type: WARRANTY PAY
Op Code Desc: F. DSC BRK PAD SSC No. ----
F. DSC BRK PAD ~|~REPLACE FRONT BRAKE SHIMS GOOD WILL ~|~DEFORMED (GOODWILL) ~|~79609 INSTALLED FRONT PADS SHIMS KIT (GOODWILL) Agreement ----
Condition 7 Pay Type: INTERNAL (DEALER) PAY
ENGINE ~|~CUST STATES VEHICLE ENGINE STUDDER ALMOST STALLS ~|~ ~|~79609 DIAGNOSTIC CHECK NO CODES PRESENT, NO START WAS CAUSE BY FLOODED ENGINE, NO REPAIR AT THIS TIME. NOTE: VEHICLE HAS 9 YEARS WARR UNLIMITED MILEAGE FOR THIS CONDITION ONLY. Agreement ----
Condition 8 Pay Type: INTERNAL (DEALER) PAY
Op Code Desc: LOAN CAR DUE BACK DAY REPAIR IS FINISHED. $100.00 A DAY THERE AFTER. GAS CHARGED SSC No. ----
LOAN CAR DUE BACK DAY REPAIR IS FINISHED. $100.00 A DAY THERE AFTER. GAS CHARGED ~|~LOAN CAR DUE BACK DAY REPAIR IS FINISHED. $100.00 A DAY THERE AFTER. GAS CHARGED $5.00 GAL. CAR MAY BE REPOSSESSED W/O NOTICE. AFTER HOURS DROP OFF SUBJECT TO A.M. INSP. FOR DAMAGE. Agreement ----
---- 12/16/2011 64,997 LEXUS OF WOODLAND HILLS-(60458) 0100563 $0.00
Op Code Desc: CERTIFIED PRE-OWNED 1ST OIL CHANGE SSC No. ----
CERTIFIED PRE-OWNED 1ST OIL CHANGE ~|~CERTIFIED PRE-OWNED 1ST OIL CHANGE ~|~1ST PRE OWNED OIL SVC ~|~64996 1ST PRE OWNED OIL SVC 001011 40 PERFORMD 1ST PRE-OWNED SVC F & R TIRES 8/32. CONTRACT# 0015673519 Agreement ----
PERFORMED TIRE PRESSURE INSPECTION AND ADJUST TO PROPER INFLATION AS MANDATED BY ~|~PERFORMED TIRE PRESSURE INSPECTION AND ADJUST TO PROPER INFLATION AS MANDATED BY STATE LAW RT FRT____ PSI LT FRT___ RT REAR PSI____ LT REAR PSI______ ~|~ ~|~64996 00 ADJUSTED TIRE PRESSURES TO 35 LBS. P.S.I. PER SVC. Agreement ----
R.O. Open R.O. Close R.O. Mileage Servicing Dealer R.O. No. R.O. Total
---- 12/16/2011 64,997 LEXUS OF WOODLAND HILLS-(60458) ---- ----
Condition 1 Pay Type: TFS
Op Code Desc: ---- SSC No. ----
Agreement 0015673519
---- 09/15/2011 61,418 VISTA LEXUS-(60411) 0158131 $0.00
Op Code Desc: REMOVE AND REPLACED REAR BUMPER DECAL SSC No. ----
REMOVE AND REPLACED REAR BUMPER DECAL ~|~REMOVE REAR BUMPER APPLICATE DECAL AS PER DUE BILL ~|~ ~|~61418 ORDERED TOUCH UP PAINT. Agreement ----
PERFORMED TIRE PRESSURE INSPECTION AND ADJUST TO PROPER INFLATION AS MANDATED BY ~|~PERFORMED TIRE PRESSURE INSPECTION AND ADJUST TO PROPER INFLATION AS MANDATED BY STATE LAW RT FRT____ PSI LT FRT___ RT REAR PSI____ LT REAR PSI______ Agreement ----
---- 07/22/2011 59,966 VISTA LEXUS-(60411) 0155246 $0.00
Op Code Desc: CERTIFIED PRE-OWNED PDI SSC No. ----
CERTIFIED PRE-OWNED PDI ~|~CERTIFIED PRE-OWNED PDI ~|~ ~|~59966 200 PERFORMED PRE-OWNED CERTIFICATION Agreement ----
Op Code Desc: PERFORM COMPLETE DETAIL SSC No. ----
USED CAR INSPECTION AND DETAIL AND RESET NAV TO READ VISTA LEXUS AS HOME DEALER ~|~USED CAR INSPECTION AND DETAIL AND RESET NAV TO READ VISTA LEXUS AS HOME DEALER TECH SIGNATURE____________________ __________ ~|~ ~|~59966 320 PERFORMED 60,000 MILE SVC REPLACED SPARK PLUGS REPLACED DRIVE BELT REPLACED DIFF FLUID REPLACED A/C FILTER REPLACED WIPER INSERTS REMOVED REAR SEAT BACK AND REPLACED MISSING SCREWS FOR LID ON REAR CUP HOLDER Agreement ----
07/15/2011 07/16/2011 59,966 VISTA LEXUS-(60411) 0155147
---- 07/15/2011 59,966 VISTA LEXUS-(60411) 0155147 $0.00
Op Code Desc: BLA TIGHTEN FUEL PRESSURE SENSOR GASKET - IS/GS SSC No. ----
BLA TIGHTEN FUEL PRESSURE SENSOR GASKET - IS/GS ~|~BLA TIGHTEN FUEL PRESSURE SENSOR GASKET - IS/GS ~|~SSC BLA ~|~59966 SSC BLA 1523A2 310 PERFORMED SSC BLA. REPLACED OVER-TORQUED GASKET Agreement ----
Op Code Desc: 9LG REPL PEDAL PAD, REFLASH, AWFM - IS MODELS ONLY SSC No. ----
9LG REPL PEDAL PAD, REFLASH, AWFM - IS MODELS ONLY ~|~ACCELERATOR PEDAL FOOT PAD REPLACEMENT AND ECU REPROGRAMMING AND REPLACEMENT OF THE AWFM IF NECESSARY ~|~SSC 9LG ~|~59966 SSC 9LG 9915M5 120 PERFORMED SSC 9LG Agreement ----
PERFORMED TIRE PRESSURE INSPECTION AND ADJUST TO PROPER INFLATION AS MANDATED BY ~|~PERFORMED TIRE PRESSURE INSPECTION AND ADJUST TO PROPER INFLATION AS MANDATED BY STATE LAW RT FRT____ PSI LT FRT___ RT REAR PSI____ LT REAR PSI______ ~|~ ~|~59966 00 ADJUSTED TIRE PRESSURES TO 35 LBS. P.S.I. Agreement ----
04/06/2010 04/06/2010 41,212 LEXUS OF THOUSAND OAKS-(60441) 0080779 $0.00
Op Code Desc: INSTRUCTED BY FTS TO PREFORM TOP ENGINE CLEANING. TECH PREFORMED OIL CHANGE WHEN SSC No. ----
INSTRUCTED BY FTS TO PREFORM TOP ENGINE CLEANING. TECH PREFORMED OIL CHANGE WHEN ~|~MULTIPLE WARNING LIGHTS ARE ON... CHECK ENGINE, VSC, & TRAC. CHECKED GAS CAP WITH CUST & IT APPEARED TO BE TIGHT/SECURE ~|~RAN TECH STREAM, FOUND P0300 & P0301 ARE STORED IN ECM. TEST DROVE 14 MILES TO DUPLICATE. OPENED CASE# 100950362. ~|~INSTRUCTED BY FTS TO PREFORM TOP ENGINE CLEANING. TECH PREFORMED OIL CHANGE WHEN FINISHED. CLEARED TROUBLE CODES & RESET WARNING LIGHTS. WHILE TEST DRIVING VEHICLE RAN OUT OF GAS. NECESSARY TO PUT SOME FUEL BACK IN TO COMPLETE TESTING/REPAIR Agreement ----
04/23/2009 04/23/2009 25,319 LEXUS OF THOUSAND OAKS-(60441) 0055082 $0.00
Op Code Desc: 9LA REPLACE FUEL DELIVERY PIPES FOR IS250/350 SSC No. ----
9LA REPLACE FUEL DELIVERY PIPES FOR IS250/350 ~|~9LA 9LA LEXUS FUEL DELIVERY PIPE - PARTS ON HOLD ~|~9LA CAMPAIGN ~|~9LA REPLACE FUEL DELIVERY PIPES FOR IS250/350 Agreement ----
01/17/2008 01/17/2008 6,793 LEXUS OF THOUSAND OAKS-(60441) 0019053 $0.00
Op Code Desc: TEST WITH SCAN TOOL,NO FAULTS,FOUND TIRE LOW ON AIR,ADJUST TIRE PRESSURE,RESET L SSC No. ----
TEST WITH SCAN TOOL,NO FAULTS,FOUND TIRE LOW ON AIR,ADJUST TIRE PRESSURE,RESET L ~|~TIRE WARNING LIGHT ON,TEST ADVISE. ~|~TEST WITH SCAN TOOL ~|~TEST WITH SCAN TOOL,NO FAULTS,FOUND TIRE LOW ON AIR,ADJUST TIRE PRESSURE,RESET LIGHT Agreement ----
07/26/2007 07/26/2007 136 VISTA LEXUS-(60411) 0081653 $0.00
Op Code Desc: PERSONALIZED SETTINGS SSC No. ----
PERSONALIZED SETTINGS ~|~PERSONALIZED SETTINGS ~|~PERSONALIZED SETTINGS ~|~135 001030 40 30 DAY SERVICE Agreement ----
Op Code Desc: PROGRAM BLUETOOTH PHONE, THIS IS A ONE TIME COMPLIMENTRY SERVICE TO ASSIST CUSTO SSC No. ----
PROGRAM BLUETOOTH PHONE, THIS IS A ONE TIME COMPLIMENTRY SERVICE TO ASSIST CUSTO ~|~PROGRAM BLUETOOTH PHONE, THIS IS A ONE TIME COMPLIMENTRY SERVICE TO ASSIST CUSTOMERS WITH BLUETOOTH SETUP. THERE IS A SERVICE CHARGE FOR PAIRING ADDL PHONES,RECONNECTING AND ADDL TRAINING. ~|~ ~|~135 50 BLUETOOTH PHONE WAS PAIRED Agreement ----
---- 07/09/2007 8 VISTA LEXUS-(60411) 0080601 $0.00
Op Code Desc: PERFORMED PRE-DELIVERY INSPECTION 01 SSC No. ----
PERFORMED PRE-DELIVERY INSPECTION 01 ~|~PERFORMED PRE-DELIVERY INSPECTION 01 ~|~ ~|~7 001013 200 PERFORMED PDI SERVICE.
Old 01-14-15, 07:40 PM
355F1
355F1's Avatar
Holy crap!
I'm sorry I can't help you with your current problem but I am thrilled you got 238,000 miles out of your '01.
I am hoping to hit 300,000 miles on my 2010; it has 120k on it currently since I bought her new 4.5yrs ago!
Old 01-14-15, 07:58 PM
sktn77a
sktn77a's Avatar
I hope they've given you a loaner car while they twiddling their thumbs trying to diagnose the problem. If the car is firing up fine, headlights are bright, etc, then it sounds like the battery is fine, Sounds similar to problems reported with the LS460. They can include: corroded door switches, bad start button, bad starter windings/brushes, to name but a few. Given that they've replaced the alternator (at your expense) and that probably wasn't the problem, I'd say, drive their car until they figure it out (on their dime, now)!
Old 01-14-15, 08:28 PM
whitebeast
whitebeast's Avatar
Don't forget to check your fuel systems including fuel pump, filter, rail....Not to mention that your fuel injector driver should be the problem at well (i have to replace mine like a year ago - really rear but happen)
Good Luck!!!
Where are you in CA BTW?
Old 06-24-15, 08:32 PM
Sceptre
Sceptre's Avatar
Hey OP, Any update on this? Thanks
Old 12-23-15, 02:36 PM
Sceptre
Sceptre's Avatar
So something similar happened to me where the car would start then immediately die. Then when I press the start button it would not crank anymore. Check the car for codes, no codes came up. Had the car towed to the dealership. Ended up it was the Fuel pressure senor went bad. Threw the car in safety mode.
Here was the hick-up. The fuel pressure sensor is a $50 part (denso Aftermarket) $250 (OEM). BUT because of the recall, Lexus will not install just the fuel pressure sensor, but instead will only do the whole fuel rail kit. Explained to me as liability issues. Cost $1300..... So do yourself a favor if you find yourself in my situation. Try the fuel pressure sensor first.
I will have to say, Lexus of Austin did take care of me by comping me the part and all i had to do was pay for Labor.
Old 12-23-15, 06:05 PM
sktn77a
sktn77a's Avatar
Not sure I understand - they billed you for a known recall?
Old 12-23-15, 06:15 PM
Sceptre
Sceptre's Avatar
The recall is for the gasket attached to the sensor itself. I had a bad sensor.
jennypenny
09-07-19 01:20 AM
Fizzboy7
04-18-18 08:34 PM
liquid2
08-01-17 05:40 AM
ahunny22
03-17-15 01:11 PM
sm1ke
03-28-14 07:37 PM
Quick Reply: '07 IS250 Won't Start - Dealer Can't Solve
