Doors automatic unlocking and light turns on....
Whenever im driving and when i turn into a parking structure plaza (going up a small ramp for example turning into a gas station) sometimes all my door unlocks... and my light turns on? anyone having this problem?!
I guess if parking area is dark your lights will turn on automatically. I am not sure about the door locks. Disconnect the battery. Also see how reset your windows after disconnecting your battery. it will reset everything.
this happened to me too. every time i turned into a store or a plaza where the ground is not flat, my car would lock or unlock then the lights would turn on and off on its own. after few days of ragging, i decided to dissect my car to fix the problem. note, my car is on coils. i found out that my doors are not perfectly sealed and lined up so when there is a sense of disconnection with the latches, it will do that. to fix it, i adjusted all 4 door panels so the latches can perfectly line up with the hooks to make a good seal. i hope it helps. have fun and good luck.
I think ISlow350 offered a good explanation and solution.
skiracer
RX - 4th Gen (2016-2022)
11-20-16 04:49 PM
