So my CPO just expired last week guess what happens my alternator is going just had it tested at Autozone because I had check engine light. Not one sign or nothing Some freaking luck. Went to dealer manager said nothing they can do about it. And offered me $535 deal for labor and parts. I will prob get part and do it myself.
You should at least use a volt meter to check the charge of the battery with all the accessories on to see if you will. Getting stuck somewhere would definitely cause a huge headache.
You will want to keep a phone # for a flat bed handy; as if you are to the point where the CEL/battery image is on the cluster, you might have only 1 maybe 2 short trips left on the battery. A bad alternator will drain AND can cause permanent damage to your battery. So after your alternator is replaced, I'd recommend a battery test as well.
Thanks for that. So I'm im do doing a test on battery and alternator and noticed my positive battery terminal is loose! Wow! So I believe this threw all the codes. I let the battery charge up for awhile ran test everything came back good! Snap-on tester is awesome printed this out.
