will theis wheel fit???
hey, I'm looking to get 20" wheel in my is350 which have H&R springs but idk if they gonna fit or not
the set up
20 x 10.5 with 20+ offset in the rear
20 x9 with 15+ offset up front
and I'm plaining to get
275/30 r20 rear
245/30 r20 front
will this set up work or not??? if not what should i change?
the set up
275/30 r20 rear
245/30 r20 front
what size of wheel should i go with if i do not want to do anything with my finders?
here is the wheel that I'm looking to get
http://www.ebay.com/itm/131095329812?_trksid=p2060778.m1438.l2648&ssPageName=STRK%3AMEBIDX%3AIT
the set up
275/30 r20 rear
245/30 r20 front
the set up
275/30 r20 rear
245/30 r20 front
thank you guys
i found the same rims with different offset
rear +35
front +30
is the set up good, or should i go with 19"
WHEELS SIZE: 19x8.5 19x10
OFFSET: 30 FRONT 35 REAR
i really don't know
rear +35
front +30
i really don't know
Fire Slayer
20's will be a bit more difficult to fit if you're low (rubbing the liner and full turns). I mDe them fit as well as many others. Some people think 20's are too big. It's all up to you and what you like. Those might fit a bit better but I still feel you'll need to do some fender work.
umm, i just found other rims and they seem to be a better set up
they are
20X8.5" Front, 20x10" Rear
and the offsets are
35mm Front & 38 mm Rear
do you think i could fit them with no finders work?
and what tires should i go with?
they are
and the offsets are
This thread will help since it's got the specs, pics, and what they've experienced. There is another one for "will these fit" but I think this one below is a little more helpful for me.
Everyone is steering you in the right direction too... sometimes a couple photos helps get an idea of what you'll be dealing with.
https://www.clublexus.com/forums/is-...our-setup.html
ScKcBc
01-15-10 10:09 AM
PNice972
05-22-07 08:03 PM
