What are the different between these F sport Springs or shocks?
Old 07-27-14, 07:25 PM
Gerb
Gerb's Avatar
Default What are the different between these F sport Springs or shocks?
https://www.clublexus.com/forums/2ge...shock-set.html
http://vancouver.en.craigslist.ca/bn...586308064.html 400$
http://is.sewellparts.com/accessorie...2006/1800.html 228 $
One is the shocks, other is ebiach, and last is from sewell
What are the difference between these 3? I thought there was only 1 f sport springs?
Thanks.
Old 07-27-14, 07:39 PM
Lex_Giorgio
Lex_Giorgio's Avatar
Thanks.
First one is the F Sport Shock & F Sport Spring.
Second one is Eibach springs. (NOT F Sport)
Third one is F Sport springs.
Old 07-27-14, 09:35 PM
Gerb
Gerb's Avatar
^What would the fsport shock and spring do that the normal f sport springs cant? Is the Eibach better than Fsport ? I was thinking whether to buy local or 238 at sewell thanks
Old 07-28-14, 04:52 AM
SubieChik
SubieChik's Avatar
If you buy just F Sport springs you would remove your stock springs (by compressing them) and put the F Sport springs over your stock struts. The gentleman you are reffering to is selling the full F Sport strut/spring setup so it would be a direct swap in. I'm sure the advantage is that the F Sport shock has better ride quality than the stock IS ones.
I would look into H&R springs before you consider Eibach. A lot of people are pleased with theirs.
Old 07-28-14, 10:34 AM
nacht
nacht's Avatar
Regarding springs, what is the difference between the Eibach and the F-Sport (by Eibach) springs in terms of spring rates/height? Are the F-Sports simply repackaged standard Eibach springs?
Old 07-28-14, 10:39 AM
FSportIS
FSportIS's Avatar
F Sport springs is actually made by Eibach with Lexus specification.
1 front, 0.8 rear.
Eibach has 2 version:
IS250: 1.4 front, 1 rear
IS350: 1 front, 0.8 rear.
F Sport shocks are GREAT SHOCKS made by Bilstein. This set is tuned to work best with the F Sport springs. The whole combo will give you lovely handling: smooth as button on daily driving and great handling when you push hard.
I have one Eibach IS250 on IS250 and F Sport on IS350 I actually like the handling in IS350 (F Sport spring + F Sport shocks) much more.
Old 07-28-14, 02:17 PM
Gerb
Gerb's Avatar
^ cheapest for fsport and shocks are about 600? Also they lower 1 front 0.8 rear? My driveway is steep. Lol not sure if I can make it up.
Old 07-28-14, 03:17 PM
flattire
flattire's Avatar
I have 114k miles on my car and I have only replaced the springs with H&R springs but still have the original shocks. Do you think it is time to replace the shocks? If so which do you guys recommend?
Old 07-28-14, 03:44 PM
FSportIS
FSportIS's Avatar
This is one of the many reasons why I pick F Sport over others which could be lower because I can drive up my steep driveway without problem. There are also tons of potholes in Southern CA roads and the springs are fine so far.
Old 07-28-14, 03:46 PM
FSportIS
FSportIS's Avatar
F Sport shocks because it is quality shocks made by Bilstein, tuned by Lexus to work well on IS, and it will last a long time.
Old 07-28-14, 04:58 PM
Gerb
Gerb's Avatar
Im at 109k km Also wondering when to switch the shocks.
Ill probably get the H&R springs. Vancouver roads are good. No potholes. Only thing you have to worry about is speedbumps. H&r springs dont even look that low should be able to get over speed bumps easily. Anyone have problems with speedbumps for the H&R springs?
Clarjoa
Suspension and Brakes
06-17-18 11:14 PM
cpcalkins
Suspension
10-03-10 06:35 AM
isam250
06-17-07 08:55 PM
PHML
06-29-03 05:15 PM
Quick Reply: What are the different between these F sport Springs or shocks?
