Lexus 2008 Pioneer Radio No Power
Old 05-21-14, 08:15 AM
bcb
bcb's Avatar
Default Lexus 2008 Pioneer Radio No Power
hello smart humans on the lexus forum,
i just purchased a used 2008 is250 and the radio is broken
it isn't getting any power
i got an exact radio replacement from ebay installed it and it also has no power
06 09 LEXUS IS250 86120-53430 AM FM RADIO CD 6 DISC PLAYER MP3 B46 P1809
if i use the nav or my Bluetooth phone the speakers work can i rule out the amp as a problem since the speakers work with nav and phone?
any suggestions on my next step?
thank you in advance
--bcb
Old 05-21-14, 12:07 PM
bcb
bcb's Avatar
Default Lexus 2008 Pioneer Radio No Power Reply to Thread
one thing i forgot to include
if i use a stereo cable and plug my phone into the AUX jack under the arm rest
i still don't get any sound
not sure it that helps at all
any advice would be greatly appreciated
thank you
--bcb
Old 05-22-14, 03:44 PM
Gville350
Gville350's Avatar
Sounds very similar to my problem, except when I replaced the NAV unit altogether it worked. I'd start with some of the NAV-related fuses. Check out your owners manual for the fuse locations and their names/functions.
Old 05-22-14, 05:22 PM
Droth
Droth's Avatar
looking at wiring diagram there is seperate fuse for radio, it's labelled as RAD No.3 on diagram. Goes to pin 1 of J66 (White 20 pin connector at radio). Hope that helps
Old 05-23-14, 07:51 PM
Gville350
Gville350's Avatar
I pulled and tested 6 different fuses that could have anything to do with NAV. Check under both the driver and passenger side fuse boxes.
nzasian88
04-04-20 12:56 PM
98ls400sd
12-12-17 10:33 PM
lexusdriv
04-05-17 08:10 AM
ANCL
03-18-13 06:56 AM
ctj954
01-24-12 06:27 AM
Quick Reply: Lexus 2008 Pioneer Radio No Power
