IS350 Brakes to IS250 AWD Different Question
Does anyone know if I can put 2007 IS350 RWD front calipers on with 2011 IS350 AWD Rotors? Found a good deal on both of them. I want to believe they will fit because the bolt pattern is the same for both 2007 and 2011 IS350 calipers, but I'm wondering if the changed offset of the AWD rotors would not allow the 2007 caliper to work properly. Any thoughts?
https://www.clublexus.com/forums/sus...50-brakes.html
It actually does. the 06-08 rotors have a smaller inner hub spacing so it will fit but wont rotate properly. if you buy rotors from an is350 2009+ it should work no problem because that is what I have. 09+ rotors can fit on an 06-08 but 06-08 part number rotors wont fit on an AWD. If that makes any sense
