IS350 stalling out when doing donuts?
Old 03-17-14, 05:23 PM
RocketGuy3
RocketGuy3's Avatar
Default IS350 stalling out when doing donuts?
I have some tires that need to be replaced soon, so I figured I'd have some fun with them before I tossed them. I've never tried donuts before, so naturally I had no idea what I was doing (don't worry, I went to a nice, big, open, empty lot), and I spun out repeatedly. Thing is whenever I spun out, the car would stall. Why is this? Is it a protective behavior of some kind? I feel like my car is telling me "NOPENOPENOPE. You have no idea what you're doing... that's quite enough"
Old 03-17-14, 05:30 PM
laobo979
laobo979's Avatar
Cause you need to turn traction control off with vsc. When traction is on it will try to control the vehicle from that kind of behavior so you don't get in any type if accidents.
Old 03-17-14, 05:44 PM
jdmSW20
jdmSW20's Avatar
thats the VSC fighting against what you are trying to do
Old 03-17-14, 06:02 PM
RocketGuy3
RocketGuy3's Avatar
I had VSC off. The tires were spinning up a storm, otherwise I wouldn't have spun out in the first place.
Old 03-17-14, 06:25 PM
Gville350
Gville350's Avatar
Did it turn off when you were moving or when you came to a stop?
Old 03-17-14, 07:23 PM
evileagle
evileagle's Avatar
Umm...Maybe you shouldn't be doing donuts?
Old 03-17-14, 07:48 PM
RocketGuy3
RocketGuy3's Avatar
Was hard for me to tell, but I think it was when I came to a stop.
And we should all probably stop eating pizza, drinking scotch, and watching TV, too. But where's the fun in that?
Old 03-18-14, 07:14 AM
MoeSzyslak
MoeSzyslak's Avatar
That's deep.
Old 03-18-14, 08:23 AM
RSXiMUS
RSXiMUS's Avatar
Are you positive you had VSC off? I can turn trac off while VSC is still active, I can make the biggest baddest burnout but once the car goes a little sideways it cuts the fun.
On my 2011 if I hit the trac button it says TRAC OFF, but I need to hold the button for about 5 seconds then a yellow skid warning light comes off saying VSC off. You are then free to kill yourself and the system won't bat an eye.
Old 03-18-14, 08:58 AM
edgeucated
edgeucated's Avatar
I wonder if this has to do with the brake pedal override recall
Old 03-18-14, 09:02 AM
EXL124
EXL124's Avatar
You may have had the VSC off but I believe it turns back on after a specific MPH...I think like 19mph or something like that. You have to hold the VSC button down for several seconds to completely shut it off and not come back on until you either turn it back on manually or turn off the engine and turn it back on.
Old 03-18-14, 12:42 PM
Gville350
Gville350's Avatar
Sucked in too much smoke from the tires? I've got no clue on this one. Perhaps get your alternator/battery tested.
Old 03-18-14, 06:03 PM
smokyis350
smokyis350's Avatar
You have to hold the traction control button for 5 seconds to completely turn it off.
Old 03-18-14, 06:15 PM
Jeff Lange
Keeping it Real
Forum Moderator
Jeff Lange's Avatar
Press button: Trac Off/VSC On, turns back on at 30mph or after cycling ignition.
Press and hold 3 sec.: Trac Off/VSC Off, turns back on only after pressing button again or cycling ignition.
Jeff
Old 03-18-14, 06:30 PM
dfwjohnd
dfwjohnd's Avatar
i get donuts & coffee in my 350 all the time, has not stalled out once *knocks on wood*
Quick Reply: IS350 stalling out when doing donuts?
