Pull codes P0172/P0175, need help diagnoising
Old 09-25-13, 06:46 PM
drewster12
drewster12's Avatar
It also could be the throttle body. I had the same codes and it the root issue was the throttle body was not opening and closing appropriately.
Old 09-06-14, 06:45 AM
rselby
rselby's Avatar
Smile
Yesterday I had both of these codes (p0173 p0175) pop up on my ISF, had a unmetered air leak after the MAF, ( and did a lil cleaning of the MAF sensor ) and a reset of the ECU, drove the car for like 15 or 20 miles (CEL lights was still on after the ECU reset) and next restart, they all went off , no more CEL
Old 11-02-15, 09:54 PM
LB23
LB23's Avatar
This codes appeared on the scanner. P0172 and P0175.
OK, so, after searching for info, first I cleaned the MAF sensor with a MAF cleaner.
I also changed the spark plugs. Still have the codes and have very high HC levels (and high CO)
Then, bought new and replaced the old A/F sensors of both banks.
They work perfect and the HC levels at high rpms really improved but still have high HC levels at idle. And the codes also reappeared.
What else to do guys? Any ideas
Old 11-03-15, 01:53 PM
Gville350
Gville350's Avatar
Sounds like a cat issue since you've already replaced the O2 sensors. I don't remember FL having any emissions when I lived there. Perhaps you can either replace the cats or get PPE cat/catless headers?
Old 11-03-15, 02:01 PM
Bichon
Super Moderator
Bichon's Avatar
I thought P0172 and P0175 are from the front oxygen sensors, the ones upstream of the cats.
Old 12-19-15, 09:30 AM
burny
burny's Avatar
replace the fuel cap. the rubber o-ring has worn down
Old 12-20-15, 03:47 PM
Bichon
Super Moderator
Bichon's Avatar
I'm highly skeptical of your diagnosis. Bad, loose or missing gas cap virtually always causes P044X or P045X (evaporative emissions leak) codes.
Old 12-22-15, 11:40 PM
SeanIS350
SeanIS350's Avatar
Did your codes first appear after having the ELF recall done?
Old 12-23-15, 09:43 AM
Individual
Individual's Avatar
The codes already provide the trouble areas to look for, and the system being too lean or rich are not related to the gas cap.
Usually codes P0441 and P0455 appear if it is a loose gas cap, which is an evaporate gross/small leak detected.
Old 12-25-15, 10:29 AM
Parsa
Parsa's Avatar
Originally Posted by e46m3lol
As I was driving home from work yesterday and my dashboard lit up like a Christmas tree... went to my local performance shop to get the codes checked out and i got the same ones the OP got (P0172 and P0175)
The car drives a little funny and feels like it bogs out at low RPM's and easy throttle but at WOT it acts perfectly normal. Another thing I have noticed is that the tranny shifts really hard, not sure if that is related to the car wanting to bog out at low rpm.
I do have an after market intake but I have never had issues with it in the past.
Any suggestions? I'm going to start off with re installing my stock intake and disconnecting the battery for a couple of minutes.
you literally just explained my car perfectly, any way you remember what the problem was? lol
Old 01-08-16, 09:46 PM
Whisperss
Whisperss's Avatar
Originally Posted by Individual
I pulled up the code on the repair manual, you may try looking into the trouble areas, as it could be the a/f or o2 sensors, but hopefully some of this helps:
Last Modified: 6-26-2013 6.4 C Doc ID: RM000000WC300HX
Model Year: 2006 Model: IS350 Prod Date Range: [08/2005 - ]
Title: 2GR-FSE ENGINE CONTROL SYSTEM: SFI SYSTEM: P0171,P0172,P0174,P0175; System Too Lean (Bank 1); 2006 MY IS350 [08/2005 - ]
DTC
P0171
DTC
P0172
System Too Rich (Bank 1)
DTC
P0174
System Too Lean (Bank 2)
DTC
P0175
System Too Rich (Bank 2)
DESCRIPTION
The fuel trim is related to the feedback compensation value, not to the basic injection time. The fuel trim consists of both the short-term and the long-term fuel trim.
The short-term fuel trim is fuel compensation that is used to constantly maintain the air-fuel ratio at stoichiometric levels. The signal from the Air-Fuel Ratio (A/F) sensor indicates whether the air-fuel ratio is rich or lean compared to the stoichiometric ratio. This triggers a reduction in the fuel injection volume if the air-fuel ratio is rich and an increase in the fuel injection volume if it is lean.
Factors such as individual engine differences, wear over time and changes in operating environment cause short-term fuel trim to vary from the ideal theoretical value. The long-term fuel trim controls overall fuel compensation. The long-term fuel trim compensates for long term deviations of the fuel trim from the ideal theoretical value. These long term deviations result from the corrections made by the short-term fuel trim.
If both the short-term fuel and long-term fuel trims are lean or rich beyond predetermined values, it is interpreted as a malfunction, and the ECM illuminates the MIL and sets a DTC.
I work at the dealer and am a CL member, would you be able to trust me? heh.
Thank you for this information. I have had the same two codes pop up on my 2006 IS350 RWD at different times of driving and have cleared both codes with my OBII reader being I was on my way to work the last time.
I will replace the MAF sensor and see if the codes come back.
Old 01-13-17, 04:35 PM
fortillian
fortillian's Avatar
Thumbs up
DTC
P0171
DTC
P0172
DTC
P0174
DTC
P0175
DESCRIPTION
2002 IS300, I have P0172 and P0175 codes after this winter weather in Texas. I've reset the codes and they came back quickly. Going to reset via battery disconnect and see if it comes back. If so then I'll start troubleshooting. Thanks for this info
Old 01-14-17, 05:12 PM
Solara350
Solara350's Avatar
100% sure it's the aftermarket intake , gas and engine oil , p0174 system too lean or p0175 running rich , put F Sport intake on any aftermarket intake cheap or expensive will give u this code also you might have vacuum hose leaks this also gives 0174 0175
Old 10-16-19, 10:09 AM
Revanth
Revanth's Avatar
2006 Lexus IS350 had its fuel rail and air bag recall work done yesterday. Today, My check engine light came on along with the track off light. The P0172 code came up. I went to lexus and they say its nothing to do with the recall work they did on the car. I will be out of the country for 3 weeks and gonna come back to them with this.
Old 11-24-19, 01:26 AM
Akai00
Akai00's Avatar
Bumping an old thread. Added an extra quart to my 06 IS250 (was a bit low before an oil change) and I got these codes after driving probably 50 miles. It isn't overfilled. Any ideas?
coquito
04-30-17 11:11 PM
IStonyG
IS - 1st Gen (2001-2005)
01-19-13 06:49 PM
Icy350
05-21-11 04:32 AM
06pearlex
04-02-11 12:46 PM
usmarines
Performance
08-24-06 07:47 AM
Quick Reply: Pull codes P0172/P0175, need help diagnoising
