Oem HID conversion
Old 06-03-13, 09:30 AM
soleeasii
soleeasii's Avatar
Default Oem HID conversion
If I wanted to convert a non hid IS to have factory HID do I have to change the harness from the car to the headlight?
Old 06-03-13, 10:05 AM
bob4256
bob4256's Avatar
What harness? You mean ballast?
You need a HID kit with a ballast and bulbs....
Old 06-03-13, 10:30 AM
B16da9
B16da9's Avatar
I think he means the harness on the car where the factory headlights plug into.
Now to answer the OP question, I'm honestly not sure as I don't have the wiring schematics in front of me to cross reference if all the pins match up. However if they don’t it would only be a simple thing of de-pining and moving the pins/wire to the correct location.
Also be aware that even with the factory HID headlights installed on your car you will still not have AFS or Auto level.
Old 06-03-13, 10:38 AM
GiantsFan
GiantsFan's Avatar
Get the HID kit from Sewell ... Comes with everything you need.
http://is.sewellparts.com/accessorie...2007/2400.html
Old 06-03-13, 11:12 AM
soleeasii
soleeasii's Avatar
So will that kit from Sewell work with a pre existing IS350 w/o HID?
I am able to get a set of headlights with factory ballasts but it just occurred to me that the wiring from the factory harness maybe different as the halogen h11 bulb uses a different harness.
Without the auto leveling.. Did u think it would be
More cost effective to just get an aftermarket HID kit?
Old 06-03-13, 11:38 AM
B16da9
B16da9's Avatar
Honestly if you're not planing on upgrading to the 2011+ LED headlights then it's more cost effective to go with an HID kit as the factory HID projectors suck.
Old 06-03-13, 11:48 AM
Jeff Lange
Keeping it Real
Jeff Lange's Avatar
Cost effective, yes, but the factory HID projectors are still way better than an HID kit in the factory halogen projectors. They might not have as wide a beam pattern as some other projectors, but at least they have a solid cutoff.
Jeff
Old 06-03-13, 12:38 PM
whitebeast
whitebeast's Avatar
the harness is same but you need Factory HID Headlight. AFS won't work due to your car doesn't AFS ECU.
pinpoint
05-29-14 12:40 PM
Tuanville
08-31-11 10:31 AM
timmy0tool
09-19-08 02:57 PM
2jzism
08-07-08 12:06 PM
j_version_
02-22-08 06:56 PM
Quick Reply: Oem HID conversion
