Ijdntoy led reflector
04-23-13, 03:01 PM
Quote:
Originally Posted by
pmanliu
Yeah - that one. This way the reflector stays on whenever your tail lights are on, regardless if you are braking or not. However they won't turn brighter when braking. If i were to do this mod that would most likely be the route i take
thanks.. i will rewire them today...
04-25-13, 12:13 AM
How do you wire them to stay on but also get brighter when you hit the brakes?
04-25-13, 11:17 AM
Former Sponsor
The wiring is for the LEDs are:
BLACK Wire - Negative
WHITE Wire - Running Light
RED Wire - Bright Mode
Connect the white wire to your tail light running light wire so it stays on when the tail lights are on. Wire up the red wire to your tail light's brake light wire so it gets brighter when your brakes are on.
04-25-13, 05:32 PM
Kumar350
Is there a CL discount for iJDMtoy products? I'm interested in picking up a set of these as well.
04-26-13, 11:06 AM
Former Sponsor
rcJten
Why yes there is, check out this thread
https://www.clublexus.com/forums/clu...ml#post7905621
04-26-13, 11:38 AM
Thanks for making these! Added another item to the "list."
04-26-13, 01:28 PM
I need to see more pictures with the lights at night
04-26-13, 01:50 PM
Former Sponsor
TravyTrav
Don't have many good night pictures from the back.. sorry! I'll try to get some from customers if I can and post them up.
06-07-13, 12:21 PM
Kumar350
Question would it be possible to wire these up to rear turn signals?
Yes call me I'll walk you through it.
03-30-14, 11:16 PM
Bump for updates. What you guys think? Rice or not? Thinking to pull the trigger on this!
03-31-14, 06:06 AM
I saw a 350c yesterday with these and it looked awesome! Might have to be my next mod
03-31-14, 09:11 AM
Here are mine hope this helps. I have mine wired up to my driving lights and turn signals.
10-11-14, 12:43 PM
After install get vsc and abs errors only when the lights are on
anyone else have this problem and a solution TIA!!!
09-05-16, 01:11 PM
do I need to remove the tail lights when wiring ? I'm using a posi tap connector btw.
09-05-16, 03:09 PM
