blackout headlight question
Old 01-05-13, 03:16 PM
BrightonB
BrightonB's Avatar
Default blackout headlight question
hello clublexus, so i am planning to blackout my headlights, i looked around found out some info like 200f in oven for 10 minutes and it seems its ok to keep all the wiring of the headlight while baking my headlight to pry it open. the question i have is if it was ok to leave my oem hid ballast connected to the headlight and bake it with my headlight. Also what are your best methods in opening the headlight so that the headlight dont warp easy.
Thankyou
BB~
Old 01-05-13, 09:04 PM
alee350
alee350's Avatar
just make sure "ALL" the bulbs are out including the hid's, leaving the ballast and the part that connects to the hid bulb is fine. I use a flat head and tried to pry carefully then use your kung fu grip to separate the lens. hope that helped :]
Old 01-06-13, 07:47 AM
TTechLexus
TTechLexus's Avatar
Here you go
https://www.clublexus.com/forums/is-...eadlights.html
Zmon
08-11-21 03:34 PM
AdamWhy
10-30-13 12:35 PM
JesLet
Lighting
01-05-11 06:00 PM
Quick Reply: blackout headlight question
