How long is the ECU under warranty?
^He didn't say he might need one, he said it looks like he needs one... To answer your question Chi- I believe that the ECU is actually only covered under the bumper-to-bumper warranty as it is part of the electrical system.
I stand corrected, taken straight from lexus' website:
Powertrain Warranty
The Powertrain Warranty is for 72 months or 70,000 miles, whichever occurs first. Except for the situations listed on the Basic Warranty page, this warranty covers repairs needed to fix defects in materials or workmanship of any component listed below:
Engine
Cylinder block and head and all internal parts, timing belt and cover, flywheel, oil pan, water pump, fuel pump, engine mounts, engine control computer, seals and gasket
Powertrain Warranty
Engine
Thanks Maxim and Jeff, I saw it too on the Lexus site. Well, I basically have multiple Check Engine Lights on. Since I work at an Acura dealer with a Lexus dealer next door, their techs helped me scan my codes and when they researched the codes, they all point to an ECU malfunction. One code is P0606 which is a ECM fault code.
Luckily, all my problems are covered under warranty. It wasn't too long ago I had the water pump replaced and then the catalytic converter last month. Now it's the ECU and if I can catch it, have them fix the start-up grind with the timing chain.
