Courtesy Light No Longer Working?
Old 06-25-12, 11:06 PM
G85
G85's Avatar
Default Courtesy Light No Longer Working?
I just tried to change my courtesy door light with and LED bulb but it stopped working. I might have pulled it on accident. Is there anyway I can fix it myself or something?
Old 06-25-12, 11:44 PM
adrr
adrr's Avatar
Check the fuse.
Old 06-26-12, 07:57 AM
will_is250
will_is250's Avatar
Some of the lights are tied to the dome light, so if the dome light is set to off the other lights will not turn on as well. Check if the dome is set to "door".
Old 06-26-12, 12:56 PM
my1s250
my1s250's Avatar
check dome light to see if its on or check the led because sometime you just have to turn it around incase they don't work
Old 06-26-12, 01:05 PM
birador
birador's Avatar
put the oem bulb back,if it turns on,prob your led has prob,try to turn it other way,might the polarity of the led or the terminals of leds not getting contact with the terminal of the courtesy light,if you put the oem bulb back on and still no light at all,it might be fuse or might disconnect by pulling hard.
Old 06-26-12, 01:12 PM
bob4256
bob4256's Avatar
+1 for checking the fuse
Old 06-26-12, 01:48 PM
G85
G85's Avatar
How do I check the fuse? Sorry for the noob question...
And I plugged the stock bulb back in and it doesn't turn on anymore. The dome light is switched to door cuz the passenger's door light comes on when opened. Helppp
RoseSim
05-18-18 09:41 PM
dorkacho
01-10-12 11:48 PM
thebossac
03-09-11 11:32 PM
danhtran
06-06-10 12:40 AM
ntr987
02-08-09 06:52 PM
Quick Reply: Courtesy Light No Longer Working?
