How much should i pay for an alignment?
Old 03-12-12, 08:35 AM
Mancebof
Mancebof's Avatar
Default How much should i pay for an alignment?
How much do you guys pay for an alignment on a IS250 AWD?
Old 03-12-12, 09:21 AM
Sango
Sango's Avatar
Depends on the shop, and if they can do it properly or not, and experience.
For me, I went to a good one which did my the IS RWD and AWD for about $150 each car. Drives like a charm and no problems with wear.
Old 03-12-12, 09:33 AM
BernieIS
BernieIS's Avatar
The only variable should be how long they allow you to come back for realignments if you hit a pothole or something along those lines. I go with the 6 month guarantee and pay $69.00 plus fees
Old 03-12-12, 09:50 AM
Mancebof
Mancebof's Avatar
Sounds about right. thanks guys.
Old 03-12-12, 11:22 AM
Herofmine
Herofmine's Avatar
I always paid $60.
Old 03-12-12, 11:25 AM
don
don's Avatar
I think you can get a lifetime's worth for $150 or something at Firestone. Might be worth it if you need alignments often.
Old 03-12-12, 01:58 PM
p0lo8
p0lo8's Avatar
i paid $105 at lexus dealership
Old 03-12-12, 02:06 PM
GoingBig
GoingBig's Avatar
I paid... 90ish here in San Diego.
It was the ones with a pit because my car is lowered haha, they recommended me get camber kits :[
Old 03-12-12, 04:18 PM
Gville350
Gville350's Avatar
My local Lexus dealer had a sale on alignments for $69. Perfect timing since I had just installed some BCRs.
Old 03-12-12, 04:50 PM
Sango
Sango's Avatar
DigitalDon,
I don't think Firestone's quality would be that well, even thou it is life time.
The place I got it from is well known that people who own exotic cars (like Ferrari, Lambo, Aston Martin) go to this place specifically to get it done properly.
For my cars which I brought in, they corrected the geometry (sub frame of the car) to get it aligned. Most places around the area would not do or or have experienced to do it, therefore even if one has an alignment there, they would experience a problem with the tire wear. This is assuming stock suspensions.
Old 03-12-12, 05:22 PM
kuuqi
kuuqi's Avatar
Most lifetime locations have someone trained to follow the machine's guidance. Although it's acceptable, it's not the best. For example, you might ask for 0 toe and they'll give you .03 toe on one wheel and -.02 toe on the other. As long as it's within "acceptable" range, they'll move on to the next wheel.
With that being said, it's not terrible for your tires to be off slightly (you'll probably be off by your first pothole anyway) so as long as the shop is decent, you should be okay for lifetime alignments.
But I would also like to add, I've also had a local tuning shop perform the alignment and they got it on point. What's ironic is the 2nd gen IS has no camber adjustment and being lowered on F-Sport springs, they were able to bring my camber just a click within specs. They probably moved some bolts and whatnot around but they did a fine job. A "lifetime" location will not allow this. I also asked for 0 toe all around and instead of my expected ".01" or whatnot, they made sure each corner was perfectly on 0. I paid $125 for this if you're wondering.
Lastly, you should consider lifetime alignments are anywhere between 150-250 on average. You can check for coupons from the likes of firestone or sullivan tires if you have that on their website to save a few bucks. But also keep in mind, some locations do not work on coilovers. Thus if you ever have the intention of getting coilovers, make sure to talk to your local location to make sure whether they touch them or not.
Old 03-12-12, 06:59 PM
LDNN
LDNN's Avatar
I would do this before going to Firestone or Goodyear.
Old 03-12-12, 07:31 PM
Hoovey689
Forum Moderator
Hoovey689's Avatar
should never have to pay more than $100 wherever you go for an alignment
Old 03-12-12, 07:50 PM
Sango
Sango's Avatar
Depends, if you pay for quality and to do the fine adjustments, then you pay over $100.
Learned my lesson paying under $100 at Toyota and they could not get the 99 Toyota Solara aligned correctly because it kept getting out of alignment shortly after it left the the lot. After 5 times of myself bringing it back complaining, they figured out one of the sub frame bolts was loose. Should of been able to figure that out the first time I brought it back in about the problem.
They were trying to make an excuse that the KYB struts was the reason why it couldn't align properly which as non-sense because this was my second set and the first set were fine. I confronted them about it because they said, I didn't tell them; I said I did not have to because it never caused any problems when it was aligned before when KYB was there for the first set.
Old 03-12-12, 08:25 PM
robertrios
robertrios's Avatar
yea firestone is hit or miss they do a great job on my 2IS but this last time they havent gotten my SC right yet...I have to take it back probably this weekend its not way off but its not spot on the manager is a stand up guy though he told me to come back when I called and they dont care about having springs or spacers. Not sure what they would say about coilovers but I dont think they would care either as long as your not so low that they cant get you on. Also my brother went with 20" wheels with a lip and they didnt have the adapters to accomidate his wheels. No issues with my 19" BBS. I think I paid 120 for lifetime on each car my firestone is at the mall so I just drop by go eat or shop so no hassel. People are right though they wont do the fine tuning that you get at some places to get you to 0 toe only to an acceptable range.
Quick Reply: How much should i pay for an alignment?
