Ride Comfort on bigger wheels/stretched tyres
Old 02-08-12, 11:29 PM
iinkz
iinkz's Avatar
Default Ride Comfort on bigger wheels/stretched tyres
Hi guys,
This is more aiming guys with the Varrstoen 112's.
19x9.5 +22 / 19x11 +25.
Currently i'm on stock 17x8's and considering getting these wheels with stretched tyres. 225/35/19 and 245/35/19.
For those that have this very same setup, do you feel that your ride comfort is destroyed?
Suspension wise, i'm on KW Variant V3's.
Please share your experiences!
Old 02-09-12, 05:24 PM
iinkz
iinkz's Avatar
Anyone willing to share their experiences?
Old 02-09-12, 05:32 PM
Sffd103
Fire Slayer
Sffd103's Avatar
That 11" wheel and that offset could be VERY close!!!
Old 02-09-12, 05:36 PM
Acer
Acer's Avatar
I would like to know this also
projectdna
projectdna's Avatar
i didn't have varrstoens, but i did have a similar-sized/-spec'd wheel/tire set-up.
ride comfort was terrible, since the sidewalls that typically absorbs some of the vertical forces are being stretched diagonally.
in addition, unless you enjoy the sound of your tires rubbing against your fenders, you'll need to run stiffer spring rates and heavier dampening.
on a related note, most 2is owners don't realize the trade-offs of running aggressive wheels and stretched tires for the sake of a cool parking lot stance.
Old 02-09-12, 07:31 PM
VIS250P
VIS250P's Avatar
I have experience riding wide rims and stretch tires for almost 2 years.. I never complain about comfort or negative about it.. I love it and there is nothing wrong... Just do it
Old 02-09-12, 07:38 PM
projectdna
projectdna's Avatar
^ your fenders are also taco'd, and you need rubber bands to hold the corners of your bumper to your fender.
more power if you're into that, but I look at it as more trouble than what it's worth.
Old 02-09-12, 08:16 PM
VIS250P
VIS250P's Avatar
Taco Fenders already repair LOL!!!! Rubber bands to the fender is nothing wrong with that... IF u lower the car and make a turn.. U hear rubbing and feel like tire will push the corner of bumper off.. WEll ok I shut up and let u ask other people...
Old 02-09-12, 09:10 PM
HeartmyIS
HeartmyIS's Avatar
I had 19x11 on my old wheels but a more conserve offset. I was on Falkens ad the ride was kinda bad...
Old 02-09-12, 09:16 PM
Jzsicklexi
Jzsicklexi's Avatar
I enjoy driving my car and pushing it from time to time. I'm very happy with my 19x10 and a slight stretch of 245s. Rides fine to me. Not much different than my 17s.
Old 02-09-12, 09:50 PM
iinkz
iinkz's Avatar
For those that have run this size, may i also ask how low your ride height was and what fender mods were required for both front and rears?
Also, if i did 235/35/19's for the front and a slightly bigger tyre size at the rear would this be a big difference in terms of comfort vs fender mods?
keep those responses coming, appreciate it!
Old 02-09-12, 11:31 PM
SCWB
SCWB's Avatar
I am running non-streteched tires on my 19" F8.5+235, R9.5+255 and I can feel about 10% harsher ride than my stock 17". To me stretched tire looks like a cripple. I like beefy healthy looking tires.
Old 02-10-12, 12:43 AM
LamTheSham
LamTheSham's Avatar
You're gonna need a serious pull in the rear to fit those wheels. Haha, depending on how low you go at least. If you wanna be somewhat low, you're gonna needa a pretty serious pull and a lot of fender liner cutting. Rubber band tires obviously lose ride quality, and the fact that you need stiffer suspension to prevent rubbing also contributes to a crappier ride quality. Run 215/35-19 245/35-19 with a big pull in the rear, and then have the fronts rolled flat and pulled a bit.
All in all, you get used to the stiff ride quality. You won't notice it after a while unless you're on a REALLY bad road.
Old 02-10-12, 01:48 AM
steezy
steezy's Avatar
Ride is gonna be horrible. Youre gonna have to stiffen your ride quite a bit. Less side wall = harsher ride but you gotta clear your fenders as much as you can.
IS250Slvr
01-22-19 09:00 PM
ALL4SPL
ES - 6th Gen (2013-2018)
34
05-25-18 06:42 AM
brendan999
RX - 3rd Gen (2010-2015)
27
06-15-17 05:37 AM
iceberg06
08-16-11 07:33 PM
defrag010
Suspension and Brakes
14
07-13-09 03:52 PM
Quick Reply: Ride Comfort on bigger wheels/stretched tyres
