Question About Rolling Fenders
Old 07-20-11, 02:04 PM
ApokC
ApokC's Avatar
Default Question About Rolling Fenders
I just called my local shop because I need to fix my front fender and get it rolled because I rub.
They said rolling the front fender will cause ripples.
Is there anyway to roll it without getting ripples?
I need em rolled, but the dimples he described sound like it'd look worse.
Thoughts?
Old 07-20-11, 02:13 PM
650IS350
650IS350's Avatar
My rears cut, front tab cut and created a new holding/screw points. I still rub but not like before since I run thick tires.
Old 07-20-11, 02:22 PM
KillaIS250
KillaIS250's Avatar
Gotta take it to a place that specializes in those kinda mods PJ.
Why you taking it to a local shop? You've seen the cars at the meets! Hit up people like Jason or Tommy and see where they got there's done! lol
Hoovey689
Hoovey689's Avatar
I got all 4 of my fenders rolled and no dimples or paint chipping. Sounds like the shop doesn't want to risk anything due to lack of experience on ISs or liability concerns etc... In anycase, find another shop or individual would be my suggestion
Old 07-20-11, 02:30 PM
ApokC
ApokC's Avatar
I talked to the dude at PLATINUM VIP
Old 07-20-11, 02:32 PM
KillaIS250
KillaIS250's Avatar
Platinum VIP said it would cause ripples?
Did they see the damage on your fender already?
Old 07-20-11, 03:55 PM
projectdna
projectdna's Avatar
Thoughts?
technically false, and yes, there is a way.
unless your local shop has no clue how to roll fenders or is simply inexperienced, of course they will tell you that it might turn out bad - that's a "CYA" move so you don't complain about it afterwards.
(on a related note, if your front fenders have been re-sprayed, it would be impossible for your local shop to work on your 2is and not have issues show up afterward.)
there are two mounting tabs on the inside edge of the fender that attaches the fender liner to the fender. when rolling that section, it may not turn out 100% smooth - unless the person doing the work is skilled enough to work on that and get the roll just right. in order to do that, it's a very tricky combination of the proper amount of heat and pressure. too much heat, you burn the clearcoat. not enough, spiderweb cracks. too much pressure, you unnecessarily pull the fenders out. not enough, and you end up with a half-rolled fender.
all excess verbage aside, i'd recommend albert @ awdfitted. he worked on MKsky's and my 2is's (we were the first of many afterwards), and the fender rolling job came out very well.
Old 07-22-11, 02:15 PM
ApokC
ApokC's Avatar
^^^ ya I have an appointment with Albert on Tuesday!
Thanks project
Old 07-22-11, 03:35 PM
projectdna
projectdna's Avatar
albert @ awdfitted will take care of you.
just don't forget to leave a lil' somethin' in the tip jar.
Old 07-22-11, 07:13 PM
VIS250P
VIS250P's Avatar
Well if u worry about the fender rolling will get damage.. I believe it is not gonna be 100% right way to prevent damage, fenders on my ride already mess up because Im running low offset rims.. Rear fenders are fine and the front fenders are mess up because I have to make the car turn.. It is better then nothing to know the fender will be mess...
Old 07-25-11, 06:16 AM
Gustavo250
Gustavo250's Avatar
My boy cut mines
vipclss
03-20-13 03:05 AM
mugenh22a4
02-09-11 01:22 PM
jnguyen87
09-17-09 09:39 PM
the island
10-20-08 05:08 PM
dizazndude
Suspension and Brakes
03-13-08 02:21 PM
Quick Reply: Question About Rolling Fenders
