Old 01-06-15, 03:46 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Exterior Guides
Print Wikipost
DIY to install the 11' Fsport lip?
Old 11-14-11, 03:55 AM
  #31
MrBBQ
MrBBQ's Avatar
Looks hot, do I see halo's in the headlights?
Old 11-14-11, 04:17 AM
  #32
Rash
hmm
Rash's Avatar
Nope, it's just the 2011 headlight.
Old 11-14-11, 02:06 PM
  #33
Cuztom350
Cuztom350's Avatar
looks good even though your not done.
Old 11-14-11, 08:24 PM
  #34
10lexISR6
10lexISR6's Avatar
just got mine a couple days ago and finally installed it today. I see nobody has ventured to attempt a no cut install, so I did today! All the clips in which youre suppose to cut is once again held on by double stick tape just as the rear gfx lip. I simply pryed them off but intact just incase i need to put them back for some reason. I used red 3m tape and applied to areas in which would be making contact. There are plenty of places on the bottom which the canards bolt and clip to the factory bumper so im not too concerned about the security of these staying in place. they fit perfect as they should and super secure.
As you can see the spots and pieces i removed.
3m tape in place
Obviously theres a few steps i forgot to document such as the bolts placement on the bottom and placement of the black included clips. Its pretty simple really, not rocket science what so ever. Once you get into it youll figure it out. hope you like and this helps some.
Old 11-14-11, 09:47 PM
  #35
Trza
Trza's Avatar
Would ya look at that... it can be done without cutting the bumper! Good work, I believe you are the first to do it that way. It looks like you might have to take a heat gun to the 3M a bit, I notice that some areas seem to stick closer to the bumper than others. It's hard to see without a straight shot from above, but because you have a lighter colored car, you can see it in the shadows along the edges. However, since the pieces are so small and light, I bet those babies are on there tight with the 3M!
I've often wondered what a factory F sport bumper looks like from behind. I'm sure they would use clips the same as we do but I find it odd coming that way from the factory...someone with a factory F sport take your bumper off and take a picture
Old 11-14-11, 10:00 PM
  #36
istundra
istundra's Avatar
if i counted correctly, we should have 7 mounting points of the lip to the bumper with the no-drill method. This is very doable and it looks like it will mount securley.
Let's not forget about technique... he pioneered the no-drill method of installing the 2IS front GFX lip.
i too followed his no-drill method DIY.
06-08 GFX Clips.
http://www.infoarena.com/lexus/
not too many OG's around anymore. :/
Old 11-15-11, 12:14 AM
  #37
Rash
hmm
Rash's Avatar
^ Technique sold his car.
Thanks! can't wait to get everything done!
Old 11-15-11, 12:23 AM
  #38
MrBBQ
MrBBQ's Avatar
10lexISR6, good job man. Looks really good with the no cut method.
Old 11-15-11, 04:54 AM
  #39
10lexISR6
10lexISR6's Avatar
Thank you MRBBQ!, I hope this helps everyone else out there from this point forward.
Old 11-15-11, 09:34 AM
  #40
Jeff Lange
Keeping it Real
Forum Moderator
Jeff Lange's Avatar
I thought about attempting a no-cut install, but didn't seem like there was any reason to. I just couldn't think of a reason I'd ever want to take them off.
But that's cool anyways.
Jeff
Old 11-15-11, 09:49 AM
  #41
10lexISR6
10lexISR6's Avatar
Jeff
Yeah for me the idea of cutting my bumper is unpleasant. And maybe down the road if I want to change up my look I wouldn't want those holes there.
Old 11-15-11, 10:35 AM
  #42
Jeff Lange
Keeping it Real
Forum Moderator
Jeff Lange's Avatar
That's true. It does fit pretty well, and with the way the piece fits into the bumper where the fog light is and with the clips, etc. underneath, it's still on there pretty securely. Not a bad idea, and it was my plan originally, but once the bumper was off and it was so easy to make the holes, I just went for it.
Jeff
Old 01-03-12, 11:49 PM
  #43
kegleyb
kegleyb's Avatar
Does anyone know why the Sewell website says these splitters aren't compatible with a "Non F-Sport Bumper"? If the only difference between the bumpers are the splitters & the grille, it doesn't make sense.
Old 01-04-12, 07:54 AM
  #44
1herm4
1herm4's Avatar
More than likely is because there is cutting involved. I have a 2011 with lux package (non f sport) and it fits just fine. I used the cut method
Old 04-03-12, 11:10 PM
  #45
devoid
devoid's Avatar
Any input regarding attempting the no-cut method in a snowy climate? I'd rather not cut my bumper but am concerned about these things coming off when driving in some thick snow. Thanks
Quick Reply: DIY to install the 11' Fsport lip?
