humming noise that increases w/ speed
Old 08-21-11, 09:54 PM
FutureITR
FutureITR's Avatar
I bet, all tires are different. When tires tend to wear down, it'll hum more. Some, louder than others. Especially sport tires!
Old 03-18-12, 12:19 PM
08lexus350
08lexus350's Avatar
hey guys i just replaced my front wheel hub on my lexus is350, i had my abs vsc and traction light on, i thought after my change of the hub it would go off and it didn't. any idea why it didn't or do i have ti take it to the dealership., thanks a lot
Old 06-17-16, 01:29 PM
rmklotz4
rmklotz4's Avatar
Originally Posted by Sango
AWD or RWD?
If it's AWD, maybe what you're hearing is the transfer case that is near the the driver's right foot. That sound would be audible throughout the front dash area. Nothing could be done about that, if this is what you are referring to.
Sango - I recently came across this thread. I am hearing a similar sound that is described here and I DO have the AWD f sport. Right at 35-50 mph I hear a rhythmic humming noise. goes away at higher speeds.
What noise does the transfer case create? Could this be the noise I am hearing?
Old 06-18-16, 06:54 AM
RandyIS250
RandyIS250's Avatar
For Toyota Lexus when ABS and CEL gone wrong the traction comes with it, ABS light indicator means one of your ABS sensor is malfunction. Who told you to replace the wheel hub ?
if your car stored code YOU SHOULD CHECK WITH SCAN TOOL not assuming, go to a shop that has an ABS scan tool tell them to scan which sensor is shot, in the mean time take out your wheel and check all the ABS wire see if anything loose check the ABS Module too if something came loose.
usually crappy mechanic broke ABS wire while replacing strut, i've had this nightmare before because that mother F ker liar mech lied to me, he broke the sensor and used super glue to stick it back lol
Old 06-18-16, 06:58 AM
RandyIS250
RandyIS250's Avatar
Its normal for a Performance car like Lexus BWM and Merc bro. i hear that noise too and i love it ! one of the pro Lexus tech told me, damn if you want quiet car then go buy a V6 Camry lol
neecharles
05-15-16 08:39 AM
rkw77080
07-29-14 02:21 PM
Enigmatic
12-20-10 06:13 PM
kate
01-23-06 03:48 PM
PUNK em all 733
09-11-03 01:39 PM
Quick Reply: humming noise that increases w/ speed
